NAS Recovery Guide for Marvell NAS
最後修訂日期: 2025-07-02
Applicable Models
  • TS-435 XeU
Overview
NAS Recovery Requirements
To recover the NAS, the following are required:
  • An empty USB drive of at least 8GB capacity
  • A 2-pin jumper
  • A Windows PC
  • A Ubuntu PC or a Ubuntu virtual machine
Recovering the NAS
To recover the NAS, follow the steps below.
Create a USB boot drive
  1. Format the USB drive as ext4:
    1. Find and install a Windows utility which can format USB drive to ext4 file system
      (e.g.: MiniTool Partition Wizard )
    2. Plug in USB drive to the Windows PC and format it to ext4 file system.
      Warning
      Formatting a USB drive will erase all its existing data. If you have data on the USB drive you want to preserve, copy the data to your PC first.
    3. The USB drive is formatted.
  2. Download the system image TS-453XeU.
  3. Boot into Ubuntu or a Ubuntu virtual machine.
  4. Mount the USB drive
  5. Copy the system image to the USB drive.
  6. Rename the system image to "emmc_recovery_fi.img".
Connect a jumper to the USB Copy pin on the motherboard
  1. Power off the NAS.
  2. Remove all drive trays.
  3. Remove the case cover of the NAS. For instructions on removing the cover, see the user guide of your NAS.
  4. Connect the jumper to the USB COPY pin:
  1. Connect the USB boot drive to a USB port on the NAS.
  2. Power on the NAS.
    The NAS starts up and the status LED starts blinking red. If the NAS starts up successfully, an audio beep will occur every 0.5 seconds for several seconds then the NAS will shut down.
    Warning
    If the status LED becomes solid red and an audio beep occurs every 0.5 seconds, then the NAS cannot start up and cannot be recovered. For more information, see Further Troubleshooting below.
  3. If the NAS started up successfully, then continue. Otherwise see Further Troubleshooting below.
  4. Remove the USB boot drive.
  5. Disconnect the jumper from the USB COPY pin.
  6. Attach the case cover of the NAS.
  7. Power on the NAS.
Install the latest firmware on your NAS with Qfinder Pro
  2. Open Qfinder Pro.
    Tip
  4. Right click on your NAS.
  5. Select Update Firmware.
  7. Click Start.
    The NAS firmware is updated to the latest version.
Install Hard Drives
After the firmware is updated, perform the following steps to install hard drives:
  4. If the hard drives are new, you can continue to initialize the NAS. For details on initializing QTS, see QTS Initialization (5.0.x).
Further Reading
Firmware Recovery Guide
這篇文章有幫助嗎?
謝謝您,我們已經收到您的意見。
請告訴我們如何改進這篇文章:
如果您想提供其他意見,請於下方輸入。
      歡迎隨時洽詢! 歡迎隨時洽詢!
