NAS Recovery Guide for Legacy x86-based NAS
最後修訂日期: 2025-07-18
Applicable  Models
  • TS-509 Pro, TS-809 Pro, TS-809U
  • TS-239 Pro, TS-239 Pro II, TS-239 Pro II+, TS-439 Pro, TS-439 Pro II, TS-439 Pro II+, TS-639 Pro, SS-439, SS-839
  • TS-259 Pro, TS-259 Pro+, TS-459 Pro, TS-459 Pro+, TS-459 Pro II, TS-459U, TS-459U+, TS-559 Pro, TS-559 Pro+, TS-559 Pro II, TS-659 Pro, TS-659 Pro+, TS-659 Pro II, TS-859 Pro, TS-859 Pro+, TS-859U, TS-859U+
  • HS-251, HS-251+, TS-x51 Series, TS-x51+ Series, TS-x51U Series
  • TS-x53 Series
  • TS-453mini
  • TS-439U
  • TS-469 Pro, TS-469L, TS-469U-RP
  • TS-569 Pro, TS-569L, TS-669 Pro, TS-669L, TS-869 Pro, TS-869L, TS-869U-RP, TS-1269U-RP
  • TS-451S
  • TS-x53U Series, TS-x53S Series
Overview
NAS Recovery Requirements
  • An empty USB drive of at least 1 GB capacity
  • A USB keyboard
  • An HDMI™ cable, or a VGA cable
  • A Windows PC
  • A monitor
Recovering the NAS
You can recover your NAS by first creating a boot disk to restore basic NAS functionality and then updating the firmware with Qfinder Pro. If any part of the recovery process fails, see Further Troubleshooting below. To recover your NAS, perform the following steps:
Prepare the NAS and verify the state of the DOM
  1. Power off the NAS.
  2. Remove all drive trays.
  3. Connect the USB keyboard to a USB port on the NAS.
  4. If the NAS has a VGA or HDMI™ port, connect the NAS to a monitor with a corresponding HDMI™ or VGA Cable.
  5. If the NAS does not have either a VGA or HDMI™ port but does have a console port, then connect the NAS to a monitor via the console port. For details see, How do I enter BIOS and Console with 3.5mm Console port?
  6. Power on the NAS
    BIOS information is displayed including the version and release date of the BIOS.
  7. Wait until the DOM (Disk-on-module) starts up.
    If the DOM fails to start up completely, then the DOM data has been corrupted and you can continue following this guide to recover the NAS.
Create a USB boot drive
  1. Download and install the Windows version of UNetbootin.
  2. Download the following Linux ISO file: http://distro.ibiblio.org/damnsmall/current/dsl-4.4.10-initrd.iso
  3. Connect the USB drive to a USB port on your PC.
  4. Format the USB drive as FAT32:
    1. Open File Explorer.
    2. Open File Explorer.
    3. Locate the USB drive.
    4. Locate the USB drive.
      A context menu appears.
    5. Click Format.
      The USB Format window appears.
    6. Under File system, select Fat32.
    7. Click Start.
      A confirmation window appears explaining that all data will be erased on the flash drive.
      Warning
  5. Open Unetbootin.
  6. For Distribution, select Damn Small Linux.
  7. For Diskimage, select ISO.
  8. Click "...".
  9. Locate and select the downloaded Linux ISO file from the previous steps.
  10. Click OK.
  11. For Type, select USB Drive.
  12. Click OK
    UNetbootin installs the Linux ISO onto the USB drive.
  13. After installation is completed, click Exit.
  14. Download the NAS system image below corresponding to the NAS model:
  15. Rename the NAS system image to "dom.img".
  16. Copy "dom.img" to the root folder of USB drive.
    The USB drive can now be used as a USB boot drive to recover your NAS system's DOM.
Use the USB boot dive to recover the corrupted DOM
  2. Connect the USB drive to a USB port on the NAS.
  3. Power on the NAS and while the NAS is starting up, press the F11 key repeatedly until the NAS displays the BIOS menu.
    Tip
    The F11 key must be pressed at a specific time to trigger the BIOS menu. Pressing the F11 key repeatedly helps ensure the key will be pressed at the correct time.
  4. Under Boot Device, select the USB drive.
    Warning
    Do not select USB DISK MODULE PMAP.
  5. On the following menu, select Default for monitor setting.
  6. Press Enter.
    The NAS starts up and the following window is displayed:
  7. Press Ctrl+Alt+Del to open the command line.
  8. Input the following command:
    sudo su
    fdisk –l
    The following partitions are present:
    PartitionDescription
    /dev/sdaThe USB boot device
    /dev/sdb or /dev/hdaThe DOM (Disk On Module) which is either 126 MB or 515 MB in size
  9. Enter the following commands:
    mkdir usbdrive
    mount /dev/sda1 /home/dsl/usbdrive
    cd /home/dsl/usbdrive
  10. Enter the following command:
    cp dom.img {0}
    VariableDescription
    {0}The path of the DOM. Either "/dev/sdb" or "/dev/hda"
    The NAS system image "dom.img" is copied from USB boot drive to the DOM.
  11. Reboot your NAS with the following command:
    reboot
    The NAS starts up correctly and Qfinder Pro can now find your NAS.
Update the NAS firmware (For firmware versions 1.x.x)
If the NAS system image downloaded above is version 1.x.x, then you must update your firmware to a newer version to complete the recovery process. Follow the steps below to update your firmware:
  1. If the NAS is a TS-239, TS-439, TS-439U, TS-509, TS-639, TS-809, TS-809U, SS-439 or SS-839, follow the steps in this tutorial:
    http://wiki.qnap.com/wiki/NAS_Firmware_Update_When_No_HDD(s)_Installed
  2. For all other x-86 based NAS, use Qfinder Pro to update the firmware:
    2. Open Qfinder Pro.
      Tip
    4. For details on using Qfinder Pro, see Qfinder Pro Help.
    5. Select Update Firmware and login with the default admin credential.
    7. Click Start.
Install hard drives
  1. After the firmware is updated, perform the following steps to install hard drives:
      For details on installing hard drives, see your NAS User Guide availble for download from Download Center.
    4. If the hard drives are new, you can continue to initialize the NAS. For initializing QTS or QuTS hero on your NAS, see the following:
      2. QTS Initialization (5.0.x)
Further Reading
Firmware Recovery Guide
這篇文章有幫助嗎?
51% 的人認為有幫助。
謝謝您,我們已經收到您的意見。
請告訴我們如何改進這篇文章:
如果您想提供其他意見,請於下方輸入。
      歡迎隨時洽詢! 歡迎隨時洽詢!
