QNA-T310G1S
        Connect to 10GbE SFP+ networks over Thunderbolt™ 3
        The QNAP QNA series is a cost-effective Thunderbolt 3 to 10GbE adapter that empowers your Mac® or Windows® computers with blazing-fast 10GbE network connectivity using a Thunderbolt 3 type-C port. And of course, it can be used with QNAP Thunderbolt™ 3 NAS to add additional 10GbE connectivity. With the portable QNA series adapter, a 10GbE network can be created between your Thunderbolt 3 computer and another 10GbE-capable device or NAS to facilitate high-speed data transfer for large files and help to streamline collaborative workflows to improve efficiency.
 ● Not compatible with Windows® OS running on ARM-based processors.
● Windows®11 devices: The driver for the Marvell AQtion AQC100; Aquantia® is required to use the QNA-T310G1S. Click here to download drivers
● Windows®10 devices: The driver for the QNA is required to use the QNA-T310G1S. Click here to download drivers
● Mac® devices: Supports macOS 10.13.3 (or later). M1, M2, M3 chips compatible.
● Linux: Supports Linux core 3.10, 3.12, 3.2, 4.2, and 4.4. The driver for the Marvell AQtion AQC100; Aquantia® is required to use the QNA-T310G1S. Click here to download drivers
                                                    10GbE data transfer that media professionals need
As video resolutions move from 1080p, to 4K, 8K (and beyond) media creators are struggling with the storage and network requirements needed for editing huge multimedia files. The QNA-T310G1S features one 10GbE SFP+ port, allowing you to easily add 10GbE connectivity to any Thunderbolt 3 device. Coupled with a QNAP 10GbE switch, a budget-friendly 10GbE environment can be created for creative studios to benefit from the incredible speed and bandwidth that 10GbE provides.
Learn More: QNAP 10GbE switch
        How to set the MTU
Mac: Open “System Preferences” → go to “Network” → Select the QNA Thunderbolt Ethernet → click “Advanced...” → go to the “Hardware” tab → change “Configure” to “Manually” → set “MTU” to “9000”.
Windows: Open "Settings" → go to "Network & Internet" → click "Change your adapter options" → right click on the Thunderbolt 3 Ethernet adapter and click "Properties" → click "Configure..." → go to the "Advanced" tab → select "Jumbo Frame" and set the value to "9KB MTU".
NAS: Open "Network & Virtual Switch" → go to "Network" > "Interfaces" → find the applicable Ethernet adapter, click  and select "Configure" → go to the "IPv4" tab → set "Jumbo Frame" to 9000.
Need help?
