How to Configure ExpressVPN on QuRouter Using OpenVPN
Last modified date: 2022-09-21
This tutorial explains how to configure ExpressVPN on QuRouter using OpenVPN.
Downloading ExpressVPN Server Information
The first step is to download a ExpressVPN OpenVPN configuration file. These files are used to configure QuRouter to access the ExpressVPN VPN server that best meets your needs.
  1. Go to https://www.expressvpn.com/.
  2. Click Setup.
    The login page appears.
  3. Enter your ExpressVPN email address and password.
  4. Click Sign In.
  5. Click Manual Configuration.
  6. Copy the usersname and the password to the clipboard.
  7. Select the region from the drop-down menu.
ExpressVPN downloads the OpenVPN configuration file.
Creating an OpenVPN Connection in QuRouter
The next step is to configure the OpenVPN QVPN connection profile settings on QuRouter using the file you downloaded earlier.
With the QVPN client service, you can connect the router to remote VPN servers using the OpenVPN protocol.
Important:
  • When adding an OpenVPN connection, an OpenVPN configuration file is required to establish the connection.
  • To enable QVPN client service, ensure that you disable QVPN server service and QuWAN service.
  1. Log in to QuRouter.
  2. Go to QVPN Clients > QVPN Connection Profiles.
  3. Click Add Profile.
    The Create an OpenVPN Connection window appears.
  4. Configure the OpenVPN connection profile.
    Setting
    User Action
    Add an OpenVPN configuration file.
    1. Click Browse.
      A File Explorer window opens.
    2. Locate the OpenVPN configuration file.
    3. Click Open.
    OpenVPN connection profile name
    Specify a name to help identify this profile.
    Username
    Enter the copied username from the ExpressVPN website.
    Password
    Enter the copied password from the ExpressVPN website.
  5. Optional: Select Automatically reconnect to OpenVPN after restarting the server.
  6. Click Add.
QuRouter adds the QVPN connection profile.
Enabling the QVPN Client Service
  3. Select an active profile.
  4. Click .
QuRouter enables the QVPN client service.
Tip:
To view the QVPN connection logs, go to QVPN Clients > QVPN Connection Logs.
89% of people think it helps.
