How to Import an ESXi Virtual Machine into Virtualization Station
Last modified date: 2020-10-16
Introduction
This tutorial explains the process of transferring a virtual machine (VM) from ESXi into Virtualization Station.
Exporting a VM from ESXi
  1. Open ESXi.
  2. Select an existing virtual machine.
  3. Select Action.
  4. Click Export.
    The Download File window opens.
  5. Select the .vmdk format.
  6. Click Export.
ESXi prepares two export files (.ovf & .vmdk) for download. You'll need both files to import the VM into Virtualization Station.
Importing a VM into Virtualization Station
  1. Open Virtualization Station.
  2. Import the VM file.
    1. Go to Overview.
    2. Click Import VM.
      The Import VM window opens.
    3. Under Import from, select PC.
      A file explorer window opens.
    4. Select the VM file.
      Important:
      ESXi will have created two files during export (.ovf & .vmdk).You'll need to select both during this step.
    5. Click Open.
      The file explorer window closes.
  3. Click Next.
  4. Configure the VM settings.
    Setting
    Description
    VM Name
    The name used to identify the VM
    Description
    The description for the VM
    CPU Cores
    The maximum number of CPU cores available to the VM
    Memory
    The maximum amount of memory available to the VM
  5. Optional: Configure the advanced settings.
    1. Click Advanced Settings.
    2. Modify any of the following settings.
      Setting
      Description
      CPU
      The CPU type used by the virtual machine
      Tip:
      This setting is typically used when exporting the VM to another device.
      Network
      The MAC address and NIC model used by the VM
      Tip:
      Click to generate a MAC address.
      Hard Disk
      The source path, cache mode, and drive controller type used by the VM
    3. Click Import.
Virtualization Station imports the VM.
Accessing the VM Console
  2. Go to VM List.
  3. Select a VM.
    The VM Information screen appears.
  4. Click .
Virtualization Station opens the VM console.
50% of people think it helps.
Still need help?
Ask the Community
