最後修訂日期: 2023-11-02
Hybrid Backup Sync
Workaround
  1. Create a new rsync storage space with Use encryption port enabled. Enter the IP address of the remote rsync server and use the Username and password of the remote rsync server that has SSH privileges.
  2. Create a new job and use this new storage space.
  3. Configure the same source and destination paths.
  4. Use the default job settings.
  5. Run the job.
Further Reading
How to backup files from a Linux OS to NAS using Rsync?
這篇文章有幫助嗎?
謝謝您,我們已經收到您的意見。
還有疑問?
在 QNAP 官方社群提問,獲得 QNAP 官方與熱心用戶的第一手建議。
前往社群發問
請告訴我們如何改進這篇文章:
如果您想提供其他意見,請於下方輸入。
