Why I don't see"Turn on the NAS automatically" in Power Recovery setting?
Applicable Products:
- Power
Power Recovery lets you specify the action the server should take when the power resumes after power loss.
Basically you can see two options,
- Restore the previous NAS power status
- Keep the NAS turned off.
Due to the hardware limitation, "Turn on the NAS automatically on" is only available in x86 Models NAS.
Related links:
