Where can I get the McAfee PAK code for my NAS running old QTS firmware?
Applicable products
- All NAS models using Intel or AMD(x86) processor, except TS-269H
- QTS 4.3.4.0435 or older
You can purchase a McAfee PAK code for the NAS running QTS 4.3.4.0435 or older by submitting a license purchase form (If you visit Software Store, clicking on QTS 4.3.4 or older will bring you the same result. )
Note: This license type (License ID) can only be for QTS 4.3.4.0483 and higher.
