NAS improper shutdown due to power outage, what should you do after power resume?
Última fecha de modificación: 2020-10-15
Applied models:
Applied Firmware:
  • All Firmware Versions
     If NAS was forced to be shutdown immediately or sudden power outage happened, system would prompt event “filesystem not clean”. Please launch “control panel” > “system” > “Storage & Snapshot” > menu of left side “storage” , then select the affected volumes , click “manage” button on the top right of windows to calling a new windows displaying the status of volume. On the new windows, click the “Action” button and choose “Check filesystem” function to check/repair the filesystem damage at the same time.
El 21% de las personas piensa que ayuda.
Gracias por sus comentarios.
Elija especificación
      Mostrar más Mostrar menos
