TS-809 Pro Specification
CPU | Intel Processor Core 2 Duo 2.8 GHz |
DRAM | 2GB DDRII RAM |
Flash Memory | 128MB DOM |
HDD | 8 x 2.5"/3.5" SATA I/II HDD NOTE:
HDD Tray | 8 x Hot-swappable and lockable tray |
LAN Port | 2 x Gigabit RJ-45 Ethernet port |
LED Indicators | Status, LAN, USB, HDD 1, HDD 2, HDD 3, HDD 4, HDD 5, HDD 6, HDD 7, HDD8, USB, LAN |
USB | 5 x USB 2.0 port (front: 1; back: 4) Supports USB printer, pen drive, USB hub, and USB UPS etc. |
Buttons | System: Power button, USB One-Touch-Backup button, reset button |
LCD Panel | Mono-LCD display with backlight and buttons for configuration |
Alarm Buzzer | System warning |
Form Factor | Tower |
Dimensions | 270 (D) x 200 (W) x 298 (H) mm 10.63 (D) x 7.87 (W) x 11.73 (H) inch |
Weight | Net weight: 8.1 kg Gross weight: 9.8 kg |
Sound Level (dB) | Standby: 35.1dB In Operation: 37.7dB; 41dB in busy read & write In Operation without HDD installed: 34dB |
Power Consumption (W) | sleep: 42W In Operation: 81W Power-off (in WOL mode): 2.25W with 8 x640GB HDD installed |
Temperature | 0~40℃ |
Humidity | 0~95% R.H. |
Power Supply | Input: 100-240V AC, 47-63Hz, Output: 350W |
Secure Design | K-lock security slot for theft prevention |
VGA | Reserved for maintenance |
Fan | 2 x 12 cm smart cooling fan |
Powerful All-in-one server |
