How to reset 2-step verification?
To reset the 2-step verification, please locate the reset button on the back of your QNAP NAS and hold it for 3-5 seconds. A short beep sound will let you know the reset has been successful.
Please note that this will also reset the QTS login to the default admin/admin.
Release date: 2017-12-26
Was it helpful?
o
