Qfinder Pro Quick Start Guide
Last modified date: 2026-01-13
  • What is Qfinder Pro?
  • System requirements
  • Before you start
  • Manage QNAP devices
    • Initialize a QNAP device
    • Update or install firmware on a QNAP device
    • Startup, shutdown, or restart a QNAP device
    • Manually add a QNAP device to Qfinder Pro
  • Manage settings for QNAP devices
    • Configure device settings
    • View device details
    • View the device Cloud Key
    • Enable SSH connections
  • Monitor performance of QNAP devices
  • Upload files and folders to QNAP devices
  • Activate licences for QNAP devices
  • Mount NAS shared folders as network drives
    • Mount shared folders on Windows
    • Mount shared folders on macOS
This guide is applicable to Qfinder Pro 7.0 and later.
Qfinder Pro is a desktop utility that allows you to quickly search and manage your QNAP devices. Qfinder Pro can connect to QNAP devices on your local internet, or via the Internet with myQNAPcloud Link. You can perform a range of essential management tasks, such as, restarting or waking-up a device, updating a device's firmware, viewing a device's real-time resource usage, or mounting shared folders on a QNAP device as network folders on your PC or macOS. Qfinder Pro allows you to quickly and efficiently manage a single QNAP device, or multiple QNAP devices simultaneously, thereby greatly streamlining and reducing your administrative overhead.
System requirements
Supported operating systems:
  • Windows 8.0 or later
  • Windows Server 2016 or later
  • macOS 12 (Monterey) or later
  • Ubuntu 18.04
Before you start
To get started using Qfinder Pro, perform the following:
  1. Connect your QNAP device to your local area network.
  2. Ensure that your computer is connected to the same local area network.
  3. Download and install Qfinder Pro on your computer.
Manage QNAP devices
You can manage various functions of your QNAP device in Qfinder Pro. The device list of the main page automatically lists all QNAP devices that can be discovered on your local area network.
LabelAreaExample Actions
1Main toolbar
  • Click on a toolbar item to access various functions and features.
Tip
Some functions require you to select a device on the device list first. To select a device on the device list, locate the device and click the device name.
2Main action bar
  • Click icons to perform various actions, including:
    • Login: Open the web portal of the selected QNAP device in your computer's default browser.
    • Details: View details of selected device.
3Device list
  • Click anywhere in the device row to select a device.
  • Right click to open the selected device's context menu.
4Context menu
  • Right click to open, and then click an action.
5Status column
  • Various status icons will appear here to indicate important information regarding your device
  • Click status icons to perform various actions.
6Refresh button
  • Click to refresh the device list. When refreshing, Qfinder Pro lists all devices that are bookmarked or discoverable on your local network.
7Quick action bar
  • Click icons to perform various actions.
Initializing a QNAP device involves installing an operating system on your QNAP device and configuring the basic settings required for the device to operate. For instructions on initializing QNAP devices with Qfinder Pro, see the section "Overview > QTS initialization > Initializing QTS using Qfinder Pro" in the QTS User Guide or QuTS hero User Guide.
You can manually update and install firmware on your QNAP device.
  1. Open Qfinder Pro.
  2. Find your QNAP device in the device list.
  3. Right click the table row of your device.
    The device context menu opens.
  4. Click Update Firmware.
    The Login window opens.
  5. Enter your QNAP device login credentials and click OK.
  6. Select one of the following options:
    1. Automatically update the firmware to the latest version: Update the firmware to the latest available version. This option is not available if your device already has the latest firmware version installed.
    2. Path of the system firmware image file: Select a firmware file to install. Firmware installation files can be downloaded from Download Center.
  7. Click Start.
    Qfinder updates or installs firmware on the QNAP device.
You can perform basic power operations on QNAP devices, such as starting up, shutting down, and restarting a device.
  3. Click the table row of your device to select your device.
  4. Click Tools from the main menu.
  5. Select a power operation: Sleep, Restart Device, Shut down Device, Remote Wake Up (Wake On LAN).
  6. Enter your QNAP device login credentials and click OK.
    Qfinder Pro performs the selected power operation on the device.
If your QNAP device is not automatically discovered by Qfinder Pro and listed on the main page, you can manually add the device:
  2. Near the top right of the window, click .
    The Add Devices window opens.
  3. Click one of the following options:
    1. Add devices from your QNAP account: Select a device that is linked to your QNAP account.
      Tip
      For details on linking your QNAP device to your QNAP account, see the section "myQNAPcloud > Initial setup" in the QTS User Guide or QuTS hero User Guide.
    2. Add a device via an IP address: Add a QNAP device by using that device's IP address.
  4. Follow the remaining steps to add the device.
    After the device is added to Qfinder Pro, the device will appear on the device list.
You can view and configure various settings of QNAP devices.
You can configure certain settings on your QNAP device
  4. Click the Configuration icon .
    The Configuration window appears.
  5. Select a tab and configure the related settings.
  6. Click Apply to save and apply any configuration changes.
  7. Click OK.
View device details
You can view certain details about your QNAP device
  5. Click Details from the tool menu.
    The Device Details window opens.
  7. Select a tab:
    1. System Status: Displays information related to the status of the system and storage drives.
    2. Virtual Switch: Displays information related to virtual switches configured on your device.
  8. When you are finished viewing device details, click OK to close the Device Details window.
You can view the Cloud Key of your QNAP device.
Tip
The device cloud key is required for certain operations on your QNAP device, for example when performing a system reset of your QNAP device.
  7. Go to the System Status tab.
  8. Scroll down to view the Cloud Key field.
You can enable and disable SSH connections on your QNAP device. To connect to a QNAP device via SSH, see How do I access my QNAP NAS using SSH?.
  4. Click Settings > SSH Connection Settings from the main menu.
    The SSH Connection Settings window opens.
    Tip
    If Allow SSH connections is enabled when the Connect via SSH window opens, you can click Cancel to exit without changing any settings.
  6. Enable Allow SSH connections.
  7. Click Apply.
    SSH is enabled on the selected device.
You can monitor various performance aspects of your QNAP device with Qfinder Pro
  4. Click Tools > Resource Monitor from the main menu.
    The Resource Monitor window appears.
    You can view various performance related details of your QNAP device in real time.
    Tip
    You can also use the built-in app Resource Monitor on your QNAP device. For details, see the section "System Settings > Monitoring System Status and Resource Monitor" in the QTS User Guide or QuTS hero User Guide.
You can upload files and folders to your QNAP device.
  4. Click Tools > Media Upload from the main menu, or click .
    The Media Upload window appears.
  6. Click  to create an upload job.
  7. Upload files and folders using the following methods:
    1. Click  to select files to upload.
    2. Click  to select folders to upload.
  8. Under Destination, click Change and select a destination folder on your QNAP device.
  9. Optional: Configure other upload options.
  10. Click Start Upload.
    Qfinder Pro creates an upload job for your selected files and folders.
You can activate licences for apps and services on your QNAP device.
  4. Click Settings > Activate License from the main menu.
    The License Activation window opens.
  6. Under Activate with QNAP ID, click .
    The Login to myQNAPcloud window appears.
  7. Enter the QNAP ID login credentials.
  8. Click Sign in.
    The Qfinder Pro License Activation window opens.
  9. Return to Qfinder Pro and go to the License Activation window.
  10. Select one or more licenses to activate.
  11. Click Activate.
    Qfinder Pro activates the selected licenses and a confirmation window appears.
  12. Click Close.
You can mount shared folders on your NAS as network drives on your PC or macOS computer.
  4. Click Connect > Storage Plug & Connect from the main menu.
    The Storage Plug & Connect window opens. Shared folders on your QNAP device are displayed.
    Tip
    To configure Storage Plug & Connect related settings, go to Preference > Storage Plug & Connect.
  6. Click a shared folder to select it.
    Tip
    For details on creating shared folders on your QNAP device, see the section "Privilege Settings > Shared folders > Creating a shared folder" in the QTS User Guide or QuTS hero User Guide.
  7. Click Map the Network Drive.
  8. Select a drive.
  9. Click Ok.
    Qfinder Pro mounts the NAS shared folder as a network drive on your PC.
  4. Click Connect > Network Drives from the main menu.
    The Network Drives window opens.
  5. Select an IP address and a protocol, and click OK.
     A confirmation window appears.
  6. Click Connect.
  7. Enter your Mac username and password, and then click OK.
  8. Click Connect.
    The volume selection window opens.
  9. Select a shared folder and click OK.
    The selected shared folder is mapped as a network drive.
