How many subfolder and subdirectory limitation on NAS (QTS system)?
最終更新日:
2022-06-24
Applied Products:
All NAS Series
All QTS Firmware Versions
The NAS QTS uses EXT4 file system format, which has a limit of 64000 subfolder, provided there are still inode available for use. The subdirectory limitation was base on the path length, allowing up to 256 ascii characters.
さらにサポートが必要な場合は、コミュニティで他のユーザーや QNAP の専門家にご質問ください。 QNAP コミュニティへ
