Hybrid Backup Sync
Workaround
- Create a new rsync storage space with Use encryption port enabled. Enter the IP address of the remote rsync server and use the Username and password of the remote rsync server that has SSH privileges.
- Create a new job and use this new storage space.
- Configure the same source and destination paths.
- Use the default job settings.
- Run the job.
Further Reading
Besoin d'aide supplémentaire ?
