Is there a minimum volume size limitation while doing volume shrinking?
Storage & Snapshots
Limitations
To prevent from unexpected error while doing volume shrinking on a storage pool with not much free space, the minimum volume size limitation of thick/thin volume will be displayed since QTS 5.0.1
The maximum shrinkage of a volume at one time equals 50% of the pool's free size.
