TS-853 Pro Specification
CPU Intel® Celeron® 2.0GHz quad-core processor (burst up to 2.42GHz)
DRAM
TS-853 Pro-8G: 8GB DDR3L RAM (4GB x 2)
TS-853 Pro: 2GB DDR3L RAM
Total memory slots: 2 (expandable up to 8GB)
NOTE:
1. When installing two memory modules, please ensure that they are the same size and ideally use the same type of RAM for both memory slots.
2. For the information of RAM module installation and compatible NAS models, please refer to the QNAP RAM Module Installation Guide.
Flash Memory 512MB DOM
Hard Disk Drive 8 x 3.5”or 2.5”SATA 6Gb/s, SATA 3Gb/s hard drive or SSD
NOTE:
1. The system is shipped without HDD.
2. For the HDD compatibility list, please visit Compatibility list
Hard Disk Tray 8 x Hot-swappable tray
LAN Port 4 x Gigabit RJ-45 Ethernet port
LED Indicators Status, LAN, USB, HDD 1-8
USB 3 x USB 3.2 Gen 1 port (Front: 1, Rear: 2)
2 x USB 2.0 port (Rear: 2)
Support USB printer, pen drive, and USB UPS etc.
HDMI™ 1
Buttons Power/Status, USB One-Touch-Backup, reset
Alarm Buzzer System warning
IR Receiver MCE-compatible
Form Factor Tower
Dimensions 185.2(H) x 298.2(W) x 235(D) mm
7.29(H) x 11.74(W) x 9.25(D) inch
Weight Net: 7.3 kg (16.08 lbs)
Gross: 8.6 kg (18.94 lbs)
Power Consumption (W) HDD standby: 28.62W
S3 sleep: 1.08W
In operation: 59.54W
(with 8 x 1TB HDD installed)
Sound Level* Sound pressure (LpAm) :23.4 dB(A)
Temperature 0-40˚C
Humidity 5~95% RH non-condensing, wet bulb: 27˚C
Power Supply ATX 350W, 100-240V
Secure Design Kensington security slot for theft prevention
Fan 2 x quiet cooling fan ( 12cm, 12V DC)
Operating System
QTS 4.1 (embedded Linux)
Storage Management
  1. Online Volume Expansion
  2. RAID types: Single Disk, JBOD, RAID 0, 1, 5, 6, 10, 5/6/10 + hot spares
  3. Global hot spare
  4. Online RAID Capacity Expansion***
  5. Online RAID Level Migration
  6. Storage expansion via QNAP UX-500P / UX-800P expansion unit (Max: 1 unit)
  7. Bad block scan and hard drive S.M.A.R.T.
  8. Bad block recovery
  9. RAID recovery
  10. Bitmap support
Supported Clients*
  1. Apple Mac OS 10.7 or later
  2. Linux and UNIX
Power Management
  1. Wake on LAN
  2. Internal hard drive standby mode
  3. Scheduled power on/off
  4. Automatic power on after power recovery
  5. USB and network UPS support with SNMP management
  6. System sleep mode (S3)
  1. Google Chrome
  2. Microsoft Internet Explorer 10+
  3. Mozilla Firefox
  4. Apple Safari
Access Right Management
  1. Access Right Management
  2. Import/export users
  3. User quota management
  5. Application access control for Photo Station, Music Station, Video Station, and Multimedia Station
  6. Subfolder permissions support for CIFS/SMB, AFP, FTP, and File Station
Multilingual Support
myQNAPcloud Service
  1. Private cloud storage and sharing with myQNAPcloud id (QID)
  3. Auto router (via UPnP) configuration
  4. Web-based file manager with HTTPS 2048-bit encryption
  5. myQNAPcloud Link for remote access without complicated router setup
  6. myQNAPcloud connect for easy VPN connection (Windows VPN utility)
File System
  1. Internal hard drive: EXT4
  2. External hard drive: EXT4, EXT3, NTFS, FAT32, HFS+
  1. Syncs files among multiple devices with SSL support
  2. Selective synchronization for syncing specific folders only
  3. Share team folder as a file center for team collaboration
  4. Shares files by links via e-mail
  5. Policy settings for conflicted files and file type filter support
  6. Version control: up to 64 versions.
  7. Incremental synchronization for HDD space saving
  8. Supports Windows & Mac OS
Networking
  1. TCP/IP: IPv4 & IPv6**
  2. Gigabit NICs with jumbo frame (failover, multi-IP settings, port trunking/NIC teaming )
  4. Proxy client, proxy server
  5. DHCP client, DHCP server
  6. NTP server
  7. Protocols: CIFS/SMB, AFP (v3.3), NFS(v3), FTP, FTPS, SFTP, TFTP, HTTP(S), Telnet, SSH, iSCSI, SNMP, SMTP, and SMSC
  8. UPnP & Bonjour Discovery
  9. USB Wi-Fi Adapter Support
Web Administration
  1. Personalized desktop
  2. Smart toolbar and dashboard for system status
  3. Smart fan control
  4. Dynamic DNS (DDNS)
  5. SNMP (v2 & v3)
  6. Resource monitor
  7. Network recycle bin for file deletion via CIFS/SMB, AFP and File Station
    • Automatic cleanup
    • File type filter
  8. Comprehensive logs (events & connection)
  9. Syslog client/server
  10. Mobile app: Qmanager for remote system monitoring & management
Security
  1. Network access protection with auto-blocking: SSH, Telnet, HTTP(S), FTP, CIFS/SMB, AFP
  3. FIPS 140-2 validated AES 256-bit volume-based data encryption*
  4. AES 256-bit external drive encryption*
  5. Importable SSL certificate
  6. Instant alert via E-mail, SMS, and beep
  7. Antivirus protection
Powerful All-in-one server
  2. Windows ACL
  3. Advanced folder permission for CIFS/SMB, AFP, FTP
  4. Shared Folder Aggregation (CIFS/SMB)
  1. Server Virtualization & Clustering
  2. VMware vSphere (ESXi 5.x)
  3. VMware VAAI for iSCSI and VAAI for NAS
  4. vSphere Plug-in
  5. Citrix XenServer (6.2)
  6. Windows Server 2012 R2 Hyper-V
  7. Supports Microsoft ODX
  8. QNAP SMI-S provider for Microsoft SCVMM
  2. FXP supported
  3. Passive ftp port range control
Transcode Management
  1. Transcode video files to 240p, 360p, 480p, 720p and 1080p resolution
  2. Automatic video transcoding for watched folders
  3. Hardware accelerated transcoding support
File Station
  1. Supports ISO Mounting (Up to 256 ISO Files)
  2. Support thumbnail display of multimedia files
  3. Support share download link and upload link
  4. Drag-n-drop Files via Chrome and Firefox Browsers
  5. Photo, music, and video preview and playback with hardware accelerated transcoding
  6. File Compression and decompression (ZIP and 7z)
Surveillance Station
  1. Supports over 2,700 IP cameras
  2. Includes 2 free camera licenses, up to 40 camera channels via additional license purchase
  3. Instant playback to check the recent event
  4. Online editing to edit cameras when live view
  5. Visual aid by e-map
  6. Playback and speed control by shuttle bar
  7. Video preview on playback timeline
  8. Intelligent video analytics (iva) for advanced video search
  9. Surveillance client for Mac
  10. Mobile surveillance app: vmobile (iOS and Android)
  11. Mobile recording app: vcam (iOS and Android)
Backup Station
  1. Remote replication server (over rsync)
  2. Real-time remote replication (RTRR) to another QNAP NAS or FTP server
  3. Works as both RTRR server & client with bandwidth control
  4. Real-time & scheduled backup
  5. Encryption, compression, file filter, and transfer rate limitation
  6. Encrypted replication between QNAP NAS servers
  7. Desktop backup with QNAP NetBak Replicator for Windows
  8. Apple Time Machine backup support
  9. Data backup to multiple external storage devices
  10. Third party backup software support: Veeam backup & replication, Acronis True Image, Arcserve backup, EMC retrospect, Symantec Backup Exec, etc.
Notes Station
  1. Graphical web-based editor for taking notes
  2. Integrate with NAS file system: insert attachment or image from NAS file system
  3. Event calendar and to-do list
  4. Image editor: a easy way to highlight the focus in your image
  5. Support note publishing with a single link
  6. Support key word search
  7. Provide Chrome Extension: Notes Station Clipper
    • Clip web page content to your note
  8. Mobile app: Qnotes
Cloud Storage Backup
  1. Amazon S3
  2. Amazon Glacier
  3. WebDAV-based cloud storage
  4. Microsoft Azure
  5. Open Stack
  6. Google Cloud Storage
  7. Dropbox
  8. ElephantDrive
VPN Server
  1. Secure remote access: PPTP & OpenVPN VPN services
  2. Max number of clients: 15 for PPTP & 15 for OpenVPN
Print Server
  1. Max number of printers: 3
  2. Print job display and management
  3. IP-based and domain name-based privilege control
  4. IP- and Domain Name-based Privilege Control
  2. Domain controller
  3. LDAP server, LDAP client
  4. Domain users login via CIFS/SMB, AFP, FTP, and File Station
Virtualization Station
  1. Support Virtual Machine (VM) creation to run an operating system such as Windows, Linux, Unix and Android
  2. Support importing VM from the other virtual platform, e.g. VirtualBox, VMware Workstation
  3. Support exporting VM with *.ovf, *.qvm formats
  4. VM clone
  5. VM snapshot
  6. HTML5-based shared remote console
  7. User-based permission setting
  8. Support USB device pass-through
  9. Support VM console display via HDMI™
Signage Station
  1. Support dynamic content includes video, image, music, and text message
  2. Multi-user collaboration
  3. Support email and social network sharing
  4. Support design software - iArtist Lite for Windows®
  5. Support various browser playback ( Chrome, Firefox, IE, Safari)
  6. Support most viewed, latest released and different categories content list
Mobile Apps
  1. Qfile: iOS, Android Phone, window phone
  2. Qfile HD: iPad version
  3. Qmanager: iOS, Android Phone
  4. Qmusic: iOS, Android Phone
  5. Qremote: iOS, Android Phone
  6. Qget: Android Phone
  7. Vmobile: iOS, iPad, Android Phone
iSCSI (IP SAN)
  1. iSCSI Target
  2. Multi-LUNs per Target
  3. Up to 256 Targets/LUNs Combined
  4. Supports LUN Mapping & Masking
  5. File-based LUN
  6. Online LUN Capacity Expansion
  7. Supports SPC-3 Persistent Reservation, MPIO, MC/S
  8. iSCSI LUN Backup, One-time Snapshot, and Restore
  9. iSCSI Connection and Management by QNAP Finder (Windows)
  10. Virtual Disk Drive (via iSCSI Initiator)
  11. Max No. of Virtual Disk Drives: 8
(1). Not all services are supported.
*The data encryption functions may not available in accordance to the legislative restrictions of some countries.
TS-853 Pro Ethernet cable x 2 Quick installation guide
Flat head screw x 32 (for 3.5" HDD) Flat head screw x 24 (for 2.5" HDD) Power cord
Hard disk tray key
