TS-459 Pro II Specification
| CPU | Intel® Atom™ 1.8GHz Dual-core Processor |
| DRAM |   					1GB RAM (Expandable RAM, up to 3GB)
| Flash Memory | 512MB DOM |
| HDD | 4 x 3.5” SATA 6Gb/s, SATA 3Gb/s hard drive or 2.5” SATA, SSD hard drive NOTE:
| HDD Tray | 4 x Hot-swappable and lockable tray |
| LAN Port | 2 x Gigabit RJ-45 Ethernet port |
| LED Indicators | Status, LAN, USB, eSATA, Power, HDD 1, HDD 2, HDD 3, HDD 4 |
| USB | 2x USB 3.2 Gen 1 port (Front: 1; Back: 1) 4x USB 2.0 port (Back: 4) Support USB printer, pen drive, USB hub, and USB UPS etc. |
| eSATA | 2 x eSATA port (Back) |
| Buttons | System: Power button, USB One-Touch-Backup Button, Reset button |
| LCD panel | Mono-LCD display with backlight Enter button, Select button for configuration |
| Alarm Buzzer | System warning |
| Form Factor | Tower |
| Dimensions | 177 (H) x 180 (W) x 235 (D) mm 6.97 (H) x 7.09 (W) x 9.25 (D) inch |
| Weight | Net weight: 3.65 kg (8.04 lbs) Gross weight: 4.65 kg (10.24 lbs) |
| Sound Level (dB) | w/o HDD installed: 34.7 dB Stand by: 34.1 dB In operation: 36.8 dB (with 4 x 500GB HDD installed) |
| Power Consumption (W) | Sleep mode: 19W In Operation: 35W Power-off (in WOL mode): 1W (with 4 x 500GB HDD installed) |
| Temperature | 0~40˚C |
| Humidity | 0~95% R.H. |
| Power Supply | Input: 100-240V AC, 50/60Hz, Output: 250W |
| Secure Design | K-lock security slot for theft prevention |
| VGA | Reserved VGA interface for maintenance |
| Fan | 1 x quiet cooling fan (9 cm, 12V DC) |
| Powerful All-in-one server |
| Accessories (Optional purchase): | |||||||||||
