[Aviso importante de seguridad] Se han detectado sitios web falsos de Qfinder Pro. Más información >
TS-459 Pro II Specification
CPU Intel® Atom™ 1.8GHz Dual-core Processor
DRAM
1GB RAM (Expandable RAM, up to 3GB)
NOTE:
  1. The system memory can be increased to 3GB by installing an additional 1GB/2GB SO-DIMM RAM module.
  2. For the information of RAM module installation and compatible NAS models, please refer to the QNAP RAM Module Installation Guide
Flash Memory 512MB DOM
HDD 4 x 3.5” SATA 6Gb/s, SATA 3Gb/s hard drive or 2.5” SATA, SSD hard drive
NOTE:
  1. The system is shipped without HDD.
HDD Tray 4 x Hot-swappable and lockable tray
LAN Port 2 x Gigabit RJ-45 Ethernet port
LED Indicators Status, LAN, USB, eSATA, Power, HDD 1, HDD 2, HDD 3, HDD 4
USB 2x USB 3.2 Gen 1 port (Front: 1; Back: 1)
4x USB 2.0 port (Back: 4)
Support USB printer, pen drive, USB hub, and USB UPS etc.
eSATA 2 x eSATA port (Back)
Buttons System: Power button, USB One-Touch-Backup Button, Reset button
LCD panel Mono-LCD display with backlight
Enter button, Select button for configuration
Alarm Buzzer System warning
Form Factor Tower
Dimensions 177 (H) x 180 (W) x 235 (D) mm
6.97 (H) x 7.09 (W) x 9.25 (D) inch
Weight Net weight: 3.65 kg (8.04 lbs)
Gross weight: 4.65 kg (10.24 lbs)
Sound Level (dB) w/o HDD installed: 34.7 dB
Stand by: 34.1 dB
In operation: 36.8 dB
(with 4 x 500GB HDD installed)
Power Consumption (W) Sleep mode: 19W
In Operation: 35W
Power-off (in WOL mode): 1W
Temperature 0~40˚C
Humidity 0~95% R.H.
Power Supply Input: 100-240V AC, 50/60Hz, Output: 250W
Secure Design K-lock security slot for theft prevention
VGA Reserved VGA interface for maintenance
Fan 1 x quiet cooling fan (9 cm, 12V DC)
Nota: Utilice sólo módulos de memoria QNAP para mantener el rendimiento y la estabilidad del sistema. Para dispositivos NAS con más de una ranura de memoria, utilice módulos QNAP con especificaciones idénticas y consulte el manual de usuario de hardware para instalar módulos de memoria QNAP compatibles.
Advertencia: Usar módulos no compatibles puede degradar el rendimiento, provocar errores o impedir el arranque del sistema operativo.
QNAP se reserva el derecho de sustituir piezas parciales o accesorios si las piezas originales ya no está disponibles en los fabricantes/proveedores. Cualquier reemplazo será totalmente probado y verificado para cumplir con las estrictas directrices de compatibilidad y estabilidad, y garantizará un rendimiento idéntico al de la pieza original.
Las imágenes de producto son para fines ilustrativos y pueden diferir del producto real Debido a diferencias en los monitores, los colores de los productos también pueden parecer distintos de los que se muestra en el sitio.
Los diseños y las especificaciones están sujetos a modificaciones sin previo aviso.
Powerful All-in-one server
TS-459 Pro II
CD-ROM
Ethernet cable x 2
Quick installation guide
Flat head screw x 12 (for 2.5" HDD)
Flat head screw x 16 (for 3.5" HDD)
Hard disk lock x 1
Power cord
Accessories (Optional purchase):
1GB RAM Module: RAM-1GDR3-SO-1333
2GB RAM Module: RAM-2GDR3-SO-1333
Accesorios opcionales
Los accesorios suministrados junto con el producto, como las tarjetas de expansión, el adaptador de corriente y los accesorios, están cubiertos por una garantía de un año.
Elija especificación
      Mostrar más Mostrar menos
