TS-209 Pro II Specification
CPU Marvell 5182 500MHz
DRAM 256 MB DDRII
Flash Memory 8MB
HDD 2 x 3.5" SATA I/II (the standard system is shipped without HDD)
NOTE:
  1. The system is shipped without HDD.
LAN Port 1 * Gigabit RJ-45 Ethernet port
LED Indicators Status, USB, LAN, HDD 1, HDD 2
USB 3 * USB 2.0, support USB printer, disk, digital camera, pen drive, USB hub, and USB UPS etc.
Buttons USB auto-copy button
Power button
Reset button
Alarm Buzzer System Warning
Form Factor Compact cubic type
Dimensions 214 (D)x 175 (W)x 115 (H) mm
Weight Net weight: 2.4 kg
Gross weight: 3.5 kg
Temperature 0~40°C
Humidity 0~95% R.H.
Power Supply Input: 100-240V AC, 50/60Hz, Output: 12V DC, 5A
Thermal Solution Smart Fan
Secure Design K-Lock security slot for theft prevention
Sound Level: Standby: 38 dB
In operation: 42dB
Powerful All-in-one server
Software Specifications
Operation System Linux-embedded system
Networking TCP/IP, DHCP Client, DHCP Server, CIFS/SMB, AFP, NFS, HTTP, HTTPS, FTP, DDNS, NTP, Gigabit Jumbo Frame
File System EXT3 (Internal/ external HDD)
 FAT (External HDD)
 NTFS (External HDD)
Supported Operating Systems Microsoft® Windows® 98/ ME/ NT/ 2000/ XP/ 2003/ Vista/ Windows 7 (32bit & 64bit)
Macintosh® OS X
Linux and Unix
Disk Management Single disk, RAID 0 (Disk Stripping), RAID 1 (Disk Mirroring) and JBOD (Linear Disk Volume)
Disk usage status management
Check disk (Check Linux file system)
HDD S.M.A.R.T.
Bad blocks scan
User Management User quota management (per user)
Windows AD Service support
User account management (max. 256 users)
User group management (max. 128 groups)
File System Management Network share management (max. 256 shares)
Share folder level ACL support
Unicode support
Journaling file system
Web File Manager
System Tools E-mail alert (SMTP authentication)
HDD standby mode
Disk usage alert
Automatic power on after power loss
System firmware upgrade
Change homepage logo
Back up, restore, reset system settings
Smart fan setting
Configurable management port
Easy IP filter management
Secure remote login by SSH connection; remote login by Telnet connection
USB, SNMP UPS support
Network recycle bin
Event Logs Complete system logs (system events management, connection logs, current connection of on-line users)
Multilingual Support English, Traditional Chinese, Simplified Chinese, Japanese, Korean, French, German, Italian, Spanish, Russian, Swedish, Danish, Finnish, Norwegian and Polish
Backup Management PC-client backup software- NetBak Replicator: Instant/ Schedule/ Auto-sync backup
Encrypted remote replication
RAID 1 Mirroring
Flexible data backup to external storage device via USB port (Instant, Schedule and Auto-Sync Backup)
TS-209 Pro II
Front Panel
Quick Installation Guide
CD-ROM (user manual, Quick Install Wizard and software inclusive)
Adaptor
Power cord
Ethernet cable x 1
Flat head screws x 8
Thumb Screws x 4
