How to search for files using Qsirch ?
- Qsirch
- System Requirements
- Supported File Types
- Getting Started
- Installing Qsirch on the NAS
- Installing Qsirch PC Edition
- Adding a NAS on Qsirch Mobile and Qsirch Helper
- Managing Search Sources
- Searching for Files
- Performing File Operations on Search Results
- Filtering Your Search Results
- Arranging Search Results
- Performing Miscellaneous Tasks on Qsirch
- Performing Miscellaneous Tasks on Qsirch Mobile
This applies to the following application and browser extension versions (and later): Qsirch 5.0.1 on the NAS, Qsirch 1.5.3 for Android, Qsirch 1.5.0 for iOS, Qsirch Helper 1.5.1 for Google Chrome, and Qsirch Helper 1.5.2 for Firefox.
Qsirch is a full-text search engine that helps you find files based on file name, content, and metadata. Qsirch has three applications for three different platforms, all of which are designed to help you find files on your QNAP NAS. Depending on your needs, Qsirch allows you to perform various file operations on your search results, such as sharing files to other users and locating them directly on the NAS.
Qsirch Helper allows you to search for files on your NAS using Google Chrome or Firefox. The extension also simultaneously searches for relevant files on your NAS when searching for files on the Internet.
QNAP provides different types of licenses for Qsirch. For more information on a paid license for Qsirch on the NAS, go to https://software.qnap.com/qsirch.html.
System Requirements
Qsirch on the NAS
Qsirch 5.0.1 or later must meet the following requirements.
The NAS architecture must be x86 (64 bit), ARM 64-bit, or an ARM x41 (32-bit).
For details on NAS architecture, check the hardware specifications sheet in your NAS User Guide.
The NAS model must have at least 2 GB RAM of pre-installed memory.
For details on pre-installed memory, check the hardware specifications sheet in your NAS User Guide.
The NAS must be running one of the following operating system versions or later: QTS 4.4.3, QuTScloud c4.5.2, or QuTS hero h4.5.0.
For details on updating your NAS firmware, go to the System Settings section of the appropriate operating system User Guide.
Earlier versions of Qsirch are compatible with earlier versions of QTS, QuTScloud, and QuTS hero.
Qsirch Mobile
Qsirch is compatible with Android 8 or iOS 11 or later.
Qsirch for Android and iOS are available in the Google Play Store or the Apple App Store.
Qsirch is able to search for the following file types:
| Category | File Types |
| Documents |
| Images |
| Music |
| Video |
Getting Started
You must install Qsirch on the NAS to allow Qsirch applications and browser extensions to search for files on your NAS.
Before installing Qsirch, ensure that a default volume has been configured on the NAS. For details, see the volumes section of the QTS User Guide.
This task explains how to install Qsirch PC Edition from the QNAP Utilities webpage. You can also install the Qsirch PC Edition from the QNAP Download Center or the Qsirch PC Edition official landing page.
You must add a NAS to allow Qsirch and Qsirch Helper to search for files on that NAS.
Adding a NAS on Qsirch Helper
To download Qsirch Helper, go to the extension page on Google Chrome or Firefox.
Defining additional search sources allows you to expand where Qsirch can look for files. You can include other devices by installing Qsirch on your NAS and adding the device as a search source.
Additionally, you can include your PC within the search scope by installing Qsirch PC Edition. By default all computers that install and configure Qsirch PC Edition are included as part of the search scope.
Adding a Search Source
You must install Qsirch on the NAS that you want to add as a search source.
Modifying an Existing Search Source
Searching for Files
Qsirch allows you to search for files on your NAS.
Searching for Files on the NAS Using Qsirch
This task only applies to Qsirch on the NAS.
To access Qsirch on the NAS, you must log in first.
Searching for Files Using an Interactive Map
Qsirch only finds photos that have a GPS location.
Searching for Files Using People Image Search
You can use People Image Search to find all photos of a person.
Searching for Files Using Qsirch Mobile
Searching for Offline Files Using Qsirch Mobile
This task only applies to Qsirch mobile.
By adding files to the Download folder, you can search for them offline. Changing the download folder does not remove previous files from the Offline search.
Searching for Files on the NAS Using Qsirch Helper
Simultaneous search in Qsirch Helper allows you to search for relevant files on your NAS while searching for files on the Internet. This feature is enabled by default.
Depending on the platform, you can open, download, share, or locate your search results using built-in or third-party applications. Qsirch on the NAS allows you to perform file operations on a file with or without previewing a file. To preview documents using Qsirch on the NAS, you must enable Cloud Viewer. For details, see Previewing Files Using Cloud Services.
Enabling Cloud Viewer allows you to preview documents on Qsirch. Depending on your preferences or needs, you can choose to preview files using the Google Docs Viewer or the Microsoft Office Viewer.
Performing File Operations on Qsirch With File Preview
This task applies to Qsirch on the NAS.
Performing File Operations on Qsirch Without File Preview
| Option | User Action |
| Downloads files to your PC. |
| Shares the file. |
| Locates the file on File Station. |
Performing File Operations on Qsirch Mobile
Performing File Operations on Qsirch PC Edition
The tasks described in this section applies to Qsirch on the NAS. There are different ways to narrow your search results. Depending on your needs, you can choose to include or exclude files and add or remove filters. Users on a Lite license can only apply three filters for each category. To add more filters, you must purchase Qsirch Premium for Qsirch on the NAS from the QNAP Software Store.
The Qsirch mobile application supports searching by category and filtering your search results. For more information, see Searching for Files Using Qsirch Mobile.
Adding and Removing Filters
Using Filters on Qsirch
Excluding Folders or Files From the Indexing Scope
Qsirch can skip over excluded folders and files for faster searches.
Only users in the administrator group can access this feature. For more information, see the Privilege section in the user guide for your operating system.
Using Advanced Image Index to Find Files
Advanced Image Index gives you more control over what images Qsirch looks for in specific folders.
Only users in the administrator group can change this setting. For more information, see the Privilege section in the user guide for your operating system.
Qsirch allows you to arrange your search results directly on the application.
Arranging Search Results on Qsirch
This task applies to Qsirch.
| View your search results in thumbnail or list view. |
| Sort your search results. |
Using Qfiling to Organize Your Search Results
With Qfiling, a QNAP file organization application, you can easily categorize your search results to different folders on the NAS. For more information, see the Creating a Task section of the Qfiling tutorial.
This applies to Qsirch on the NAS.
These tasks are designed to help you manage Qsirch and configure various settings for better productivity.
Finding Previous Searches
Qsirch keeps previously used keywords and categories to save your time when search on your NAS.
Downloading a Debug Report
If you are experiencing problems with Qsirch, download a debug report and contact QNAP Technical Support for further assistance.
Checking Your License Information
You can directly access License Manager to manage an existing license or the QNAP Software Store to buy a license.
Depending on your needs, you can use Qsirch to perform other miscellaneous tasks and configure the application.
Managing Background Tasks
Configuring Settings
Adding a QNAP ID
You can add more than one QNAP ID to give you more search options. Adding a QNAP ID adds all NAS devices associated with that account to Qsirch.
Deleting a QNAP ID
You can delete a QNAP ID and all its associated devices from Qsirch mobile or only remove the QNAP ID information.
Still need help?
, select
from the search results screen to search your NAS files by category.
and select a filter.
and select
and then select
and click
beside the section title. To clear selected filters for all sections, click
beside
