NAS improper shutdown due to power outage, what should you do after power resume?
Applied models:
Applied Firmware:
All Firmware Versions
If NAS was forced to be shutdown immediately or sudden power outage happened, system would prompt event “filesystem not clean”. Please launch “control panel” > “system” > “Storage & Snapshot” > menu of left side “storage” , then select the affected volumes , click “manage” button on the top right of windows to calling a new windows displaying the status of volume. On the new windows, click the “Action” button and choose “Check filesystem” function to check/repair the filesystem damage at the same time.
