How to Use QVR Center Failover Management
Last modified date: 2025-09-15
Introduction
QVR Center 2.0.0 (and later versions) supports adding servers into a Failover Group to set up failover protection. Failover management in QVR Center helps ensure the recording persists if an error occurs in your recording server.
Note
  • You can add up to 16 Failover Groups and 64 servers in each Failover Group for an x86_64 server while ARM64 server (TS-AI642) can manage up to 8 servers for each Failover Group.
  • QVR Center only supports QVR Surveillance (including TVR-AI200), QVR Elite, and QVR Pro servers with Advanced Mode enabled to add to a Failover Group. For more information, see What is Advanced Mode in QVR Center?
Adding Servers to a Failover Group
The first Failover Group is created by default, titled “Failover Group 1.”
  1. Click Failover Management on the side menu.
  2. Start adding servers in Failover Group 1 or add another Failover Group by clicking at the side of the tab.
  3. Click and then select one or more servers to be added as recording servers, and then click Apply.
  4. Click and then select one or more servers to be added as standby servers, and click Apply.
Tips
Servers are eligible to become standby servers when they fulfill the following criteria:
  • At least one empty recording space
  • An empty camera list
  • Not yet added to another Failover Group
  • License channels must be equal to or more than any of the recording servers’ license channels
Disabling Servers in a Failover Group
  2. Perform one of the following actions:
    1. Toggle the switch under the Action column of a specific server to disable the server in the failover group.
    2. Toggle the switch of Failover Protection to disable the failover group.
Removing Servers from a Failover Group
  2. Click and then select one or more recording server, then click Remove to remove one or more recording servers.
  3. Click to and then select one or more standby servers, then click Remove to remove one or more standby servers. You need to verify as the first admin user to continue removing the standby server.
Note
A server that is in the takeover process cannot be removed. Disable the failover server to continue removing the server from a failover group. For more information, go to Disabling Servers in a Failover Group.
Adding a Failover Group
  2. Click at the side of the tab.
  3. Enter the name of the Failover Group.
  4. Click Add to create the failover group.
Editing a Failover Group
  2. Click on the Failover Group tab, and select Edit.
  4. Click Apply to apply the settings.
Deleting a Failover Group
  2. Click on the Failover Group tab, and select Delete.
  3. Verify as the first admin user, and click Delete to remove the failover group from QVR Center.
Warning
Upon deleting a Failover Group, any takeover process will be interrupted immediately.
Note
"Failover Group 1" is the default Failover Group, which cannot be deleted.
Failover Status
Recording server's Failover Status:
IconFailover StatusDescription
Normal, protectedThis recording server is functional, and is able to be taken over by standby server.
Normal, unprotectedThis recording server is functional, but is unable to be taken over by standby server either because there are no available standby server or the standby server does not have enough licensed channel quota to fully take over this server.
Abnormal, protectedThis recording server is not functioning properly, and is taken over by standby server now.
Abnormal, unprotectedThis recording server is not functioning properly, and is unable to be taken over by standby server either because there are no available standby server or the standby server does not have enough licensed channel quota to fully take over this server.
DisabledThis recording server is disabled in the Failover Group.
Standby server's Failover Status:
Normal, protection readyThis standby server is functional, and is ready to take over recording server.
Normal, protectingThis standby server is functional, and is currently taking over a recording server.
WarningThis standby server is functional, but is unable to take over recording server because it does not have a recording space.
AbnormalThis standby server is not functioning properly, and is unable to take over recording server.
Abnormal, protection failedThis standby server is not functioning properly, and has failed to take over a recording server.
DisabledThis standby server is disabled in the Failover Group.
Further Reading
  1. The QVR Center product page provides more detailed introduction and examples.
  2. Why can't I add server as a standby server to enable failover in QVR Center?
  3. What is Advanced Mode in QVR Center?
  4. How do I enable failover function in QVR Center? | QNAP
