How does the power button function on my QNAP NAS?
Last modified date: 2025-10-15
  • All QNAP NAS models
Overview
The power button on your QNAP NAS allows you to turn the device on and off. However, the required press-and-hold durations for a software or hardware shutdown differ depending on the hardware platform of your NAS model (x86 or ARM).
Details
You can perform a software or hardware shutdown by holding the power button for a specific duration:
PlatformSoftware Shutdown
(Press & Hold Duration)
Hardware Shutdown
x861.5–2 seconds5–6 seconds
ARM (e.g., TS-831X)4–5 seconds9–10 seconds
If you do not hold the button for the required time, the NAS will remain powered on and the shutdown will not occur.
Note: A software shutdown safely powers off your NAS by shutting down all services, while a hardware shutdown performs a forced power off (only use if the NAS is unresponsive).
Alternative: You can also shut down the NAS from the web GUI. Simply log in, go to the main menu, and select Shut Down from the power options.
Further Reading
78% of people think it helps.
      Chat with us! Chat with us!
