How do I find network speed bottleneck?
Last modified date:
2022-06-24
Applicable Products:
- Network
Follow the procedures below
- Direct connect the NAS and a PC/Mac by ethernet cable and copy a single 4GB iSO file from the NAS to the PC by Windows File Explorer/macOS finder, the expected speed should be around 100MB/s in 1Gbps network.
- Connect the other wired network devices back one by one and copy the same file check if the slow speed happens in connecting certain device.
- Connect the wireless network devices and run the same test.
Still need help?
