How to Configure Astrill on QuRouter Using OpenVPN?
This tutorial explains how to configure Astrill VPN on QuRouter using OpenVPN.
Downloading Astrill Server Information
The first step is to download an Astrill OpenVPN configuration file. These files are used to configure QVPN Service to access the Astrill VPN server that best meets your needs.
Creating an OpenVPN Connection in QuRouter
The next step is to configure the OpenVPN QVPN connection profile settings on QuRouter using the file you downloaded earlier.
With the QVPN client service, you can remotely connect the router to VPN servers using the OpenVPN protocol.
When adding an OpenVPN connection, an OpenVPN configuration file is required to establish the connection.
To enable QVPN client service, ensure that you disable QVPN server service and QuWAN service.
QuRouter adds the QVPN connection profile.
Enabling the QVPN Client Service
QuRouter enables the QVPN client service.
To view the QVPN connection logs, go to .
to download all the certificates in a zipped file.
to download a single OpenVPN configuration file.
