Configuring QNAP NetBak Replicator
QNAP NetBak Replicator provides several options for copying files from your Windows computer to your NAS. By simplifying the backup process, NetBak Replicator helps ensure that your files are safe even when your computer becomes unavailable.
Before you can start using NetBak Replicator, you must first complete the initial configuration process.
To download and install NetBak Replicator, go to https://www.qnap.com/en/utilities.
  1. Open NetBak Replicator.
  2. Click Start.
    NetBak Replicator displays all QNAP NAS devices connected to the local area network.
  3. Select the NAS and then click Next.
  4. Select the shared folder and then click Next.
  5. Specify your NAS user name and password, and then click OK.
    Tip:
    You can select Remember username and password to save your login informaiton.
  6. Click Finish.
QNAP NetBak Replicator is configured and ready for use.
Release date: 2017-03-21
Was it helpful?
32% of people think it helps.
o
