QVR DoorAccess Help Document
Last modified date: 2021-03-24
Integration with QNAP Applications
QVR DoorAccess integrates with existing QNAP applications such as QVR Pro and QVR Face to provide a smarter, safer, and more convenient door access system.
QNAP applications can provide a complete access control system. QVR Pro captures video streams. QVR Face performs facial recognitions on the streams. QVR DoorAccess checks the facial recognition data against approved files. If approved, QVR Pro triggers an open-door signal to allow access.
Name
Description
QVR Pro
QVR Pro is a comprehensive surveillance system that leverages the powerful storage features of the QNAP NAS.
QVR Face
QVR Face is a QTS application that analyzes camera streams and videos for facial recognition, delivering real-time analytics results and providing instant event notifications.
QVR DoorAccess
QVR DoorAccess is an intelligent door system that is fast and easy to deploy and manage. It can be easily integrated into an existing door access system with support for third-party card systems.
About QVR DoorAccess
QVR DoorAccess is an intelligent door system that is fast and easy to deploy and manage. With support for third-party card access control systems, you can also easily integrate QVR DoorAccess into your existing door access system.
System Requirements
Category
Requirements
Hardware
A compatible QNAP x86 models NAS
Software
  • QTS 4.5.1 or later
  • Container Station version 1.9 or later
Getting Started
  1. Install QVR DoorAccess on your NAS.
    For details, see Installing DoorAccess.
  2. Purchase a QVR DoorAccess license.
    For details, see Purchasing a License.
  3. Add a controller.
    This step is optional if there is an existing door access control system. For details, see Adding a Controller.
  4. Add a door.
    For details, see Adding a Door.
  5. Add users.
    For details, see Adding a User.
  6. Add door access rules.
    For details, see Adding a Door Access Rule.
  1. Log on to QTS as administrator.
  2. Go to App Center, and then click .
    A search box appears.
  3. Enter QVR DoorAccess.
    The QVR DoorAccess app appears in the search results.
  4. Click Install.
    QTS installs QVR DoorAccess.
Basic Operations
Checking a License
  1. Open QVR DoorAccess.
  2. Click .
    The QVR DoorAccess License window appears.
  3. Click Go to License Center.
    QVR DoorAccess redirects you to License Center.
  2. Click .
  3. Click Go to Software Store.
    QVR DoorAccess redirects you to the QNAP Software Store.
Adding a Controller
  2. Go to Controllers.
  3. Click Add Controller.
    The Add Controller window appears.
  4. Specify the controller information.
  5. Optional: Click Test to test the connection.
  6. Click OK.
    QVR DoorAccess adds the controller.
Adding a Door
  2. Go to Doors.
  3. Click Add Door.
    The Add Door window appears.
  4. Specify the door name.
  5. Click Controller, and then select up to two controllers.
  6. Click Action, and then enter the URL names and URLs for trigger actions.
  7. Click OK.
    QVR DoorAccess adds the door.
Adding a User
  2. Go to Users.
  3. Click Add User.
    The Add User window appears.
  4. Specify the user information.
  5. Click OK.
    QVR DoorAccess adds the user.
Importing a User
  2. Go to Users.
  3. Click Import.
    The Import Users window appears.
  4. Click Browse and then select a file to import.
  5. Click Next.
  6. Select the users you want to import.
  7. Click Finish.
    QVR DoorAccess imports the users.
Configuring the Access/Deny List
  2. Go to Users.
  3. Select the users you want to deny.
  4. Click Set Deny List.
    The Set Deny List window appears.
  5. Click Yes.
    The users are moved to the Deny List.
  2. Go to Access Rules.
  3. Click Add Access Rule.
    The Add Access Rule window appears.
  4. Specify the rule name.
  5. Optional: Click Schedules, and then set the date.
  6. Click OK.
    QVR DoorAccess adds the door access rule.
Exporting Logs
You can export logs and keep a copy on your local device.
  2. Go to Logs.
  3. Click Export.
    QVR DoorAccess exports the logs as a CSV file. You can open the file or save it to a desired folder on your device.
36% of people think it helps.
      Chat med os! Chat med os!
