TVS-AIh1688ATX Specification
  1. TVS-AIh1688ATX-U9-48G (Legacy)
    CPU Intel Core Ultra 9, 24 (8P+16E) core, 24 Threads, up to 5.6GHz
    CPU Architecture 64-bit x86
    Graphic Processors Intel® Graphics
    Encryption Engine (AES-NI)
    Neural Processing Unit (NPU)
    System Memory 48GB ECC UDIMM DDR5
    Maximum Memory 192 GB (4 x 48 GB)
    Memory Slot 4 x UDIMM DDR5
    For dual-DIMM configurations, you must use a pair of identical DDR5 modules.
    Drive Bay 12 x 3.5-inch SATA 6Gb/s, 3Gb/s + 4 x 2.5-inch U.2 NVMe Gen 4 x2 slots
    2.5-inch bays:
    2.5-inch U.2/SATA SSD
    Hot-swappable
    5 Gigabit Ethernet Port (5G/2.5G/1G/100M) Optional via an adapter
    10 Gigabit Ethernet Port 2 x 10GBASE-T (10G/5G/2.5G/1G)
    25 Gigabit Ethernet Port Optional via an adapter
    Wake on LAN (WOL)
    Jumbo Frame
    Thunderbolt Port Optional via the QXP-T52P 2-port Thunderbolt 5 PCIe adapter
    Supports only Thunderbolt connections for Windows & Mac hosts and USB storage devices. Third-party Thunderbolt external storage devices are not supported.
    PCIe Slot 3
    Slot 1: PCIe Gen4 x16
    Slot 2: PCIe Gen4 x4
    Slot 3: PCIe Gen4 x4
    Card dimensions for PCIe slot 1:260 x 111.15 x 37.52 mm / 10.25 x 4.38 x 1.48 inches.
    Card dimensions for PCIe slot 2:150 x 68.9 x 18.76 mm / 5.90 x 2.71 x 0.74 inches.
    Card dimensions for PCIe slot 3:150 x 68.9 x 18.76 mm / 5.90 x 2.71 x 0.74 inches.
    Wider cards can be installed if the next PCIe slot will not be used."
    USB 3.2 Gen 2 (10Gbps) Port 3 x USB3.2 Gen2 Type-A
    2 x USB3.2 Gen 2 Type-C
    USB 4 port 2 x USB4 Type-C
    HDMI™ Output 1, HDMI™ 2.1 (up to 4096 x 2160 @ 60Hz)
    Form Factor Tower
    LED Indicators System status, LAN, USB, Disk 1~16
    LCD Display/ Button
    Buttons Power, Reset, USB Auto Copy
    Dimensions (HxWxD) 294.3 × 369.89 × 319.8 mm
    Weight (Net) 13.8 kg
    Operating Temperature 0 - 40°C (32°F - 104°F)
    Power Supply Unit 750W PSU, 100~240V
    Power Consumption: Disk Standby Mode 97.036 W
    Power Consumption: Operating Mode, Typical 130.83 W
    Fan System fan: 3 x 80mm, 12VDC
    CPU fan: 2 x 97mm, 12VDC
    System Warning Buzzer
    Kensington Security Slot
    Standard Warranty 5 years
    Max. Number of Concurrent Connections (CIFS) - with Max. Memory 10000
  2. TVS-AIh1688ATX-U9-32G
    System Memory 32GB ECC UDIMM DDR5
    2.5-inch bays:
    Hot-swappable
    Wake on LAN (WOL)
    Jumbo Frame
    PCIe Slot 3
    Form Factor Tower
    LCD Display/ Button
    Standard Warranty 5
  3. TVS-AIh1688ATX-U7-32G
    CPU Intel Core Ultra 7, 20 (8P+12E) core, 20 Threads, up to 5.3GHz
    2.5-inch bays:
    Hot-swappable
    Wake on LAN (WOL)
    Jumbo Frame
    PCIe Slot 3
    Form Factor Tower
    LCD Display/ Button
  1. Operating System
    QuTS hero h5.6.0
    Supported Languages
    Storage Pool
    SED Storage Pool
    Maximum Pool size
    5 PB
    128
    Shared Folder Type
    Thick, Thin
    Maximum shared folder size
    5 PB
    256
    VJBOD / VJBOD Cloud
    iSCSI Service
    Fibre Channel Service
    LUN Type
    Thick, Thin
    Block-based iSCSI LUN
    Maximum LUN size
    1024 TB
    Maximum number of targets LUN
    256
    RAID Type
    RAID Group
    RAID Hot Spare
    Global, Local
    RAID Sync/Rebuild/Scrubbing
    End-to-End data integrity
    Internal drive
    ZFS
    External drive
    Disk, Enclosure Locate
    Disk S.M.A.R.T. Scan
    Ironwolf Health Management
    Secure Erase
    SSD Trim
    SSD Life Estimation
    Disk Roaming
    Disk Standby
    Shared Folder Snapshot
    LUN Snapshot
    Maximum Snapshot (Per System)
    Minimum Snapshot Interval
    1 minute
    Snapshot Retention Policy
    Self-serve Snapshot Recovery
    Snapshot Full Clone
    Snapshot Instant Clone
    Snapshot Replica / Vault
    SSD read-only Cache
    SSD read & write log cache
    SSD dedicated ZIL cache
    SSD Cache Maximum Size
    SSD Cache RAID
    0, 1, 10 (journal)
    External Device Management
    Mount Smart Phone (MTP)
    3. Apple networking (AFP)
    3. FXP support
    Maximum FTP connection
    1024
    Shared Folder WORM
    File Station (Web)
    Object Storage
    Local user account
    16,000
    Local group account
    512
    Domain user/group account
    200,000
    Domain Security
    Domain Controller
    Shared folder permission
    Windows ACL
    User quota
    Group quota
    Folder quota
    Home folder
    Resource Monitor
    SNMP
    V2, V3
    Network recycle bin
    Smart Fan
    Schedule on/off
    Internet protocol
    IPv4, IPv6
    Virtual Switch
    Port trunking
    , (7 modes)
    DHCP Server
    Malware Remover
    2-step verification
    Allow/Deny List
    Access Protection
    Service binding
    Firewall
    vSphere Web Client Plug-in
    VMware vSphere VAAI for iSCSI
    VMware vSphere VAAI for NAS
    Windows ODX
    Windows/VMware Snapshot Agent
    HTTP/HTTPS Connections
    TLS 1.0/1.1/1.2/1.3
    Supports WebDAV Connection
    Supports Virtual Hosts
    32
    [Qsync] Management Mode
    User customization, Central
    64
    HBS (Hybrid Backup Sync)
    400
    Hyper Data Protector
    [Boxafe] Office 365 Backup
    [Boxafe] Full-text search
    [Qsirch] Previews
    [Qsirch] Integrate Mac Finder
    [Qsirch] Search filters
    [QuMagie] Browse photos
    Antivirus (free)
    McAfee (License)
    QVPN Service
    [QVPN Service] Remote Access
    100
    HD Station
    LDAP Server
    RADIUS
    SQL server
    License Center
    Multimedia Console
    Video Station
    Notes Station
    Media Streaming add-on
    QmailAgent
    DA Driver Analyzer
    Q'center
    Q'center Server
    Q'center Agent
    Connect to Q'center
    Virtualization Station
    All function is Fine.
    Can create a virtual switch
    GPU function is fine
    LXC/LXD and Docker
    Linux Station
    16.04, 18.04, and 20.04
    Linux Station Center
    QVR Surveillance
    Standard MP4 file based
    Subscription-based, Perpetual
    Android and iOS
    H.264
    Developing
    QVR Center
    [QVR Center] Log management
