TVS-AIh1688ATX Specification
TVS-AIh1688ATX-U9-48G
CPU Intel Core Ultra 9, 24 (8P+16E) core, 24 Threads, up to 5.6GHz CPU Architecture 64-bit x86 Graphic Processors Intel® Graphics Floating Point Unit Encryption Engine (AES-NI) Hardware-accelerated Transcoding Neural Processing Unit (NPU) System Memory 48GB ECC UDIMM DDR5 (1 x 48 GB) Maximum Memory 192 GB (4 x 48 GB) Memory Slot 4 x UDIMM DDR5 For dual-DIMM configurations, you must use a pair of identical DDR5 modules.Flash Memory 5GB (Dual boot OS protection) Drive Bay 12 x 3.5-inch SATA 6Gb/s, 3Gb/s + 4 x 2.5-inch U.2 NVMe Gen 4 x2 slots Drive Compatibility 3.5-inch bays:
2.5-inch bays:
2.5-inch U.2/SATA SSDHot-swappable SSD Cache Acceleration Support 2.5 Gigabit Ethernet Port (2.5G/1G/100M) 2 (2.5G/1G/100M/10M) 5 Gigabit Ethernet Port (5G/2.5G/1G/100M) Optional via an adapter 10 Gigabit Ethernet Port 2 x 10GBASE-T (10G/5G/2.5G/1G) 25 Gigabit Ethernet Port Optional via an adapter Wake on LAN (WOL) Only the 2.5GbE portJumbo Frame Thunderbolt Port Optional via the QXP-T52P 2-port Thunderbolt 5 PCIe adapter Supports only Thunderbolt connections for Windows & Mac hosts and USB storage devices. Third-party Thunderbolt external storage devices are not supported.PCIe Slot 3
Slot 1: PCIe Gen4 x16
Slot 2: PCIe Gen4 x4
Slot 3: PCIe Gen4 x4Card dimensions for PCIe slot 1:260 x 111.15 x 37.52 mm / 10.25 x 4.38 x 1.48 inches.
Card dimensions for PCIe slot 2:150 x 68.9 x 18.76 mm / 5.90 x 2.71 x 0.74 inches.
Card dimensions for PCIe slot 3:150 x 68.9 x 18.76 mm / 5.90 x 2.71 x 0.74 inches.
Wider cards can be installed if the next PCIe slot will not be used."USB 3.2 Gen 2 (10Gbps) Port 3 x USB3.2 Gen2 Type-A
2 x USB3.2 Gen 2 Type-CUSB 4 port 2 x USB4 Type-C HDMI™ Output 1, HDMI™ 2.1 (up to 4096 x 2160 @ 60Hz) Form Factor Tower LED Indicators System status, LAN, USB, Disk 1~16 LCD Display/ Button Buttons Power, Reset, USB Auto Copy Dimensions (HxWxD) 294.3 × 369.89 × 319.8 mm Weight (Net) 13.8 kg Operating Temperature 0 - 40°C (32°F - 104°F) Storage Temperature -20 - 70°C (-4°F - 158°F) Relative Humidity 5-95% RH non-condensing, wet bulb: 27˚C (80.6˚F) Power Supply Unit 750W PSU, 100~240V Power Consumption: Disk Standby Mode 97.036 W Power Consumption: Operating Mode, Typical 130.83 W Fan System fan: 3 x 80mm, 12VDC
CPU fan: 2 x 97mm, 12VDCSystem Warning Buzzer Kensington Security Slot Standard Warranty 5 Max. Number of Concurrent Connections (CIFS) - with Max. Memory 10000 Note: Use only QNAP memory modules to maintain system performance and stability. For NAS devices with more than one memory slot, use QNAP modules with identical specifications and refer to the hardware user manual to install compatible QNAP memory modules.
Designs and specifications are subject to change without notice. -
TVS-AIh1688ATX-U7-32G
CPU Intel Core Ultra 7, 20 (8P+12E) core, 20 Threads, up to 5.3GHz CPU Architecture 64-bit x86 Graphic Processors Intel® Graphics Floating Point Unit Encryption Engine (AES-NI) Hardware-accelerated Transcoding Neural Processing Unit (NPU) System Memory 32GB ECC UDIMM DDR5 (1 x 32 GB) Maximum Memory 192 GB (4 x 48 GB) Memory Slot 4 x UDIMM DDR5 For dual-DIMM configurations, you must use a pair of identical DDR5 modules.Flash Memory 5GB (Dual boot OS protection) Drive Bay 12 x 3.5-inch SATA 6Gb/s, 3Gb/s + 4 x 2.5-inch U.2 NVMe Gen 4 x2 slots Drive Compatibility 3.5-inch bays:
2.5-inch bays:
Operating System QuTS hero h5.6.0
- Microsoft Windows 7, 8, 10, and 11
Storage Pool SED Storage Pool Maximum Pool size 5 PB
Shared Folder Type Thick, Thin
Maximum shared folder size 5 PB
Maximum number of shared folder 256
JBOD Expansion VJBOD / VJBOD Cloud iSCSI Service Fibre Channel Service LUN Type Thick, Thin
Block-based iSCSI LUN Maximum LUN size 1024 TB
Maximum number of targets LUN 256
RAID Type - 8-bay (and more): Single, RAID 0 (Stripe), 1, 5, 6, 10, 50, 60, Triple Mirror, Triple Parity
- 6-bay: Single, RAID 0 (Stripe), 1, 5, 6, 10, 50, Triple Mirror, Triple Parity
- 4-bay: Single, RAID 0 (Stripe), 1, 5, 6, 10, Triple Mirror, Triple Parity
- 3-bay: Single, RAID 0 (Stripe), 1, 5, Triple Mirror, Triple Parity
RAID Expansion (by replacing bigger Disks) Storage Pool Expansion (by adding RAID Group) RAID Hot Spare Global, Local
RAID Sync/Rebuild/Scrubbing End-to-End data integrity Silent error detection and self-healing Internal drive ZFS
External drive EXT3, EXT4, NTFS, FAT32, HFS+, and exFAT
Disk, Enclosure Locate Disk S.M.A.R.T. Scan Disk S.M.A.R.T. Data Migration Ironwolf Health Management Secure Erase SSD Trim SSD Life Estimation Disk Roaming Disk Standby Shared Folder Snapshot LUN Snapshot Maximum Snapshot (Per System) Maximum Snapshot (Per Volume / LUN) Minimum Snapshot Interval 1 minute
Snapshot Retention Policy Self-serve Snapshot Recovery Application Consisted Snapshot Snapshot Full Clone Snapshot Instant Clone Snapshot Replica / Vault SSD read-only Cache SSD read & write log cache SSD dedicated ZIL cache SSD Cache Maximum Size SSD Cache RAID 0, 1, 10 (journal)
External Device Management Mount Smart Phone (MTP) External RAID Device (QNAP so on) Management (External Device Mode) External RAID Device (QNAP so on) Management (NAS Mode) File Server - File sharing across Windows, Mac, and Linux/UNIX
- Apple networking (AFP)
FTP Server - FTP, SFTP and TFTP protocols
- FXP support
Maximum FTP connection 1024
Shared Folder Data Compression Shared Folder Data Deduplication Shared Folder WORM File Station (Web) Object Storage Local user account 16,000
Local group account 512
Domain Security Domain Controller Shared folder permission Windows ACL User quota Group quota Folder quota Home folder Resource Monitor SNMP V2, V3
Security Counselor Malware Remover AES 256-bit Folder Encryption validated by FIPS 140-2 CAVP 2-step verification Allow/Deny List Access Protection Service binding Firewall vSphere Web Client Plug-in VMware vSphere VAAI for iSCSI VMware vSphere VAAI for NAS Windows ODX Windows/VMware Snapshot Agent HTTP/HTTPS Connections TLS 1.0/1.1/1.2/1.3
[HybridMount] File Cloud Gateway Concurrent Connections = 80 Upload & 80 Download
[QVPN Service] Remote Access PPTP, L2TP/IPSec, OpenVPN, QBelt (QNAP proprietary)
HD Station LDAP Server RADIUS SQL server License Center Multimedia Console Photo Station Music Station Video Station Download Station Notes Station Qfiling Media Streaming add-on QmailAgent QuWAN DA Driver Analyzer Q'center Note: The application is available in the App Center and in virtual appliance marketplaces (VMware vSphere ESXi and Microsoft Hyper-V).
[Virtualization Station] GPU pass-through GPU function is fine
[Linux Station] Supports Ubuntu versions 16.04, 18.04, and 20.04
Linux Station Center QVR Elite Note: At least 1 GB RAM is required. The maximum number of channels supported varies by NAS model, network configuration, and camera settings. For more information, visit https://www.qnap.com/go/qvr-nas-selector.
[QVR Elite] Recording Technique Standard MP4 file based
[QVR Elite] License Type Subscription-based
[QVR Elite] User-defined trigger events [QVR Elite] QVR Pro Client (Desktop) Windows, macOS, and QNAP HybridDesk Station
[QVR Elite] QVR Pro Client (Mobile) Android and iOS
[QVR Elite] Recording camera streams H.264
[QVR Elite] Free built-in camera channels 2
[QVR Elite] Expandable camera channels Developing
QVR Center Note: At least 4 GB RAM is required.
[QVR Center] Log management [QVR Center] Central monitoring across multiple servers
TVS-AIh1688ATX
10GBASE-T Ethernet cable x 1
Power Cord x 1
Flat head screw x 48 (for 3.5" HDD)
Flat head screw x 36 (for 2.5" HDD)
Drive tray keys x 2
