QNA-UC5G1T
Connect to 5GbE networks over USB 3.2 Gen 1
qna-uc5g1t
The light and portable QNAP QNA-UC5G1T USB 3.2 Gen 1 to 5GbE adapter provides the ability to add an extra network port to your Windows® computer or QNAP NAS. Supporting 5GbE/ 2.5GbE/ 1GbE/ 100MbE connections, the QNA-UC5G1T is especially useful for laptops that lack native Ethernet connectivity.
Add a 5GbE Ethernet port to your Windows® laptop
To make thinner and lighter laptops, some manufacturers tend to omit Ethernet ports. With the QNA-UC5G1T you can upgrade your laptop to support 5GbE RJ45 Ethernet connectivity and take advantage of high-speed network connections.
To ensure optimal performance:
1. To ensure optimal performance, it is recommended to set the Jumbo Frames on all the devices in your local network environment to MTU 9000.
2. When using the QNA-UC5G1T with Windows PC (driver v1.8 and later), please disable the "Low Power 5 Gbps" option in the QNA-UC5G1T network adapter's property under "Device Manager".
Windows File Transfer
Windows Download
428 MB/s
Windows Upload
422 MB/s
10G File Transfer
Test Environment:
File transfer between two Windows® computers, each connecting to one QNA-UC5G1T
Client PC: Windows 10 Pro, Intel Core i7-6770 3.40GHz, 64GB RAM, QNA-UC5G1T adapter, MTU 9000
Add extra Ethernet ports to your NAS
The QNA-UC5G1T provides a quick and easy way to expand the network connectivity of your QNAP NAS. You can connect multiple QNA-UC5G1T adapters to your NAS and manage them alongside other network ports in the Network & Virtual Switch app.
1. Requires a QNAP NAS with QTS 4.3.6 (or later). QNA-UC5G1T does not support the following: the TS-131, TS-231, TS-431, TS-431U, TS-128A, TS-228A, TS-133, TS-233, TS-433. Please check the compatibility list for the NAS compatibility with the QNA-UC5G1T.
2. For optimal transfer speed, please connect the QNA-UC5G1T to the USB 3.2 Gen 1 port of your device.
3. The QNA-UC5G1T does not support Port Trunking, DHCP server, RADVD server and Static Routing.
Build a high-speed Intranet in your office or studio
QNAP provide a wide range of network devices to assist business and home users with upgrading their network infrastructure to meet growing bandwidth requirements. The QNA-UC5G1T can be coupled with other devices, including a QNAP 10GbE switch, to create a budget-friendly high-speed network environment for improving the performance of various work and entertainment applications.
Effortless setup
Simply connect a QNA-UC5G1T adapter to your Windows® computer using the included USB 3.2 Gen 1 Type-C to Type-A cable (a Type-C to Type-C cable - sold separately - can also be used) and connect the adapter to a 10GbE/ 5GbE/ 2.5G/ 1GbE-capable switch (e.g. QNAP 10GbE switch), NAS, or other device using a RJ45 LAN cable.
● Windows 10, 8.1, 8, 7 requires a driver. Requires the Marvell® AQtion AQC111U driver.Click here to download the driver. (Windows 11 and future versions are not supported.)
● QNAP NAS: QTS 4.3.6 (or later) or QuTS hero h4.5.0 (or later) is required.
  • Stylish
    Features a metallic bright-toned cover that fits perfectly alongside other devices.
  • Portable
    Requires no extra power supply and can be easily carried for universal deployment.
  • Quiet
    A fanless design with shallow grooves provides effective heat dissipation.
Need help?
  • CAB-U310G10MCC
    CAB-U310G10MCC
    USB3.1 Gen2 10G 1.0m Type-C to Type-C cable
    Dimension (L × W × H): 300 × 240 × 10 (mm)
    Weight: 0.07 (kg)
  • CAB-U35G02MAC
    CAB-U35G02MAC (EOL)
    USB3.0 5G 0.2m Type-A to Type-C cable
    Weight: 0.15 (kg)
  • CAB-U35G10MAC
    CAB-U35G10MAC (EOL)
    USB 3.2 Gen 1 5G 1m Type-A to Type-C cable
    Weight: 0.15 (kg)
