What is the difference between a static volume, thin volume, and thick volume?
Last modified date: 2025-07-01
  • Storage & Snapshots
  • QTS
Static Volumes
A static volume is a simple and easy-to-use volume which contains all the available storage capacity on the disks/RAID selected to create the volume. A static volume does not have a storage pool and does not support advanced storage features such as snapshots and Qtier. However, static volumes can still take advantage of SSD caching. A static volume is recommended for creating a simple, single volume that uses all the disks in your NAS, and you don’t need features like snapshots or Qtier. Also, due to its simplicity, the performance of a static volume is slightly better than other volume types.
Thin and Thick Volumes
Thin and thick volumes, also called flexible volumes, must be created inside a storage pool. A storage pool contains all the available storage capacity on the disks/RAID selected to create the pool. Once a pool has been created, flexible volumes can be created and will allocate storage space within the pool as required. Flexible volumes support advanced storage features such as snapshots, Qtier, and SSD caching.
Flexible volumes can also be resized, converted between thin and thick types, and backed up to a remote storage pool via Snapshot Replica.
Thin volumes allocate space in the storage pool as data is written into the volume. Only the size of data in the volume is used up from the pool space, and free space in the volume does not take up any pool space. If data is deleted from the volume, that space can be freed and given back to the storage pool free space. The pool free space is shared among all thin volumes, and the NAS administrator must take care to ensure there is enough free space in the pool as more data is written to thin volumes. In the event where there is insufficient pool space, thin volumes will enter read-delete or read-only mode until more pool space is available.
Thin volumes are recommended when you must create multiple volumes and share the storage pool space efficiently between them. Also, thin volumes are recommended if you are planning to use volume snapshots. When using snapshots with thin volumes, only modifications to existing data on the volume will increase the snapshot used space, the size will be the same as the modified data.
Thick volumes allocate the total size of the volume upon creation. No matter how much data is actually stored in the volume, the total size of the volume will always be used up in the pool. On the other hand, this space is guaranteed to be available exclusively for this volume, even if other volumes used up all remaining pool free space.
Thick volumes are recommended if you are creating multiple volumes but need to guarantee the space for a particular volume. The performance of a thick volume may also be slightly better than a thin volume in some situations.
Note
If you are using snapshots with a thick volume, writing new data to the empty space of the volume will increase the snapshot used space by the same size as the new data. You must monitor the pool free space and recycle older snapshots periodically to avoid running out of pool space. For this reason, thin volumes would be recommended when using snapshots.
The different space allocation behaviors between thick and thin volumes can be visualized in the following diagram:
Volume Type Comparison
 Volume Type
 StaticThickThin
SummaryBest overall read/write performance, but does not support most advanced featuresGood balance between performance and flexibilityEnables you to allocate storage space more efficiently
Read/write speedFastest for random writesGoodGood
FlexibilityInflexible
A volume can only be expanded by adding extra drives to the NAS.
Flexible
A volume can easily be resized.
Very flexible
A volume can be resized. Also unused space can be reclaimed and added back into the parent storage pool.
Parent storage spaceRAID groupStorage poolStorage pool
Volumes allowed in parent storage spaceOneOne or moreOne or more
Initial sizeSize of the parent RAID groupUser-specifiedZero
Storage pool space is allocated on-demand, as data is written to the volume.
Maximum sizeSize of the parent RAID groupSize of the parent storage poolTwenty times the amount of free space in the parent storage pool
The size of a thin volume can be greater than that of its parent storage pool. This is called over-allocation.
Effect of data deletionSpace is freed in the volumeSpace is freed in the volumeQTS can reclaim the freed space and add it back into the parent storage pool.
Methods of adding storage space
  • Add disks to the RAID group
  • Replace existing disks with higher capacity disks
Allocate more space from the parent storage poolAllocate more space from the parent storage pool
Snapshot support (fast backup and recovery)NoYesYes
Qtier support (automatic data tiering)NoYesYes
Further Reading
92% of people think it helps.
Still need help?
Ask the Community
