This tutorial will walk you through how to configure an access control system for your location. QNAP assumes the user has already installed and connected the required cameras and door control hardware.
QNAP applications can provide a complete access control system. QVR Pro captures video streams. QVR Face performs facial recognitions on the streams. QVR DoorAccess checks the facial recognition data against approved files. If approved, QVR Pro triggers an open-door signal to allow access.
| Name | Description |
| QVR Pro | QVR Pro is a comprehensive surveillance system that leverages the powerful storage features of the QNAP NAS. |
| QVR Face | QVR Face is a QTS application that analyzes camera streams and videos for facial recognition, delivering real-time analytics results and providing instant event notifications. |
| QVR DoorAccess | QVR DoorAccess is an intelligent door system that is fast and easy to deploy and manage. It can be easily integrated into an existing door access system with support for third-party card systems. |
QVR Face, QVR Pro, and QVR DoorAccess allow users to easily create a comprehensive access control system.
This system lets users set rules that apply to the entire location or control access to specific doors within the system.
The first step is to create an analytics task to detect people appearing in QVR Pro camera or RTSP streams. The analytics provided by QVR Face can be used for configuring profiles, groups, and event notifications for instant facial recognition.
You can create live analytics tasks to detect people appearing in QVR Pro camera streams.
- Open QVR Face.
- Go to Live Analytics Tasks.
- Click Add Video Stream.
Note: For creating subsequent tasks, click Create Task.
The Create Task window appears.
- Select From QVR Pro.
- Specify the task name and the description.
- Select an analytics threshold.
- Optional: Enable gender, age, and emotion detection.
- Click Next.
- Specify the QVR Pro login information.
| Field | User Action |
| IP address | Specify an IP address. |
| Port number | Specify a port number. Note: The default port number is 8080. |
| Username | Specify your username. |
| Password | Specify your password. |
- Click Next.
- Select a camera stream.
- Click Next.
- Click Finish.
QVR Face creates the live analytics task for the specified QVR Pro camera stream.
You can create live analytics tasks to detect people appearing in RTSP streams.
- Open QVR Face.
- Click Live Analytics Tasks.
Tip: For creating subsequent tasks, click Create Task.
- Select From RTSP.
- Click Next.
- Specify the RTSP URL and login information.
| RTSP URL | Specify an RTSP URL. |
- Click Next.
- Click Finish.
QVR Face creates the live analytics task for the specified RTSP stream.
The second step is to create profiles for members. You can create profiles for people detected in video streams and generate analytics reports to better monitor attendance and control access within your organization.
You can upload photos to create profiles for the members of your organization or your family.
Important: To increase the accuracy of facial recognition, ensure the following.
Uploaded photos are taken from various angles in which the person looks directly at the camera and 20 degrees up, down, to the left, and to the right.
Facial landmarks (shown as green dots) match the salient facial features of each person, such as eyes, nose, and lips.
- Open QVR Face.
- Click People & Groups.
- Click People.
- Click Create Profile.
The Create Profile window appears.
- Specify the profile information.
| Profile key | Specify a unique profile key to identify this person. Tip: To avoid repetition, QNAP recommends using the ID number or the phone number of the person as the profile key. |
| Name | Specify a name for the person. |
| Description | Specify a description for the person. |
| Group | Select a group for the person. Tip: To create additional groups, go to Groups and click Create Group. |
- Click
. - Select a photo source.
| Source | User Action |
| Live analytics task | Take and select photos from a live analytics task. |
| Local folder | Select photos from a local folder on your computer. |
| NAS | Select photos from a shared folder on the NAS. |
| Webcam | Take and select photos from a webcam on your computer. |
| Unknown face | Select photos from unknown people in the QVR Face database. |
Note: You can upload a maximum of 10 photos for each profile.
- Click Apply.
QVR Face creates a profile for the person.
QVR Face assigns numbers to unknown people detected in streams or videos. You can create profiles for unknown people in the database.
- Open QVR Face.
- Click People.
- Select an unknown person.
QVR Face displays the information of this person.
- Click Register new profile.
Tip: If the detected face already belongs to a registered person, click Add this person to an existing profile to add this face to the existing profile.
- Click Apply.
QVR Face registers the unknown person and creates a profile.
The last step is to create event rules in QVR Face to trigger other applications via URLs.
This topic demonstrates how to set up an event rule in QVR Face. Users with access to QVR DoorAccess can set up different access rules for each door, create independent access logs, and search recorded videos for registered profiles. QVR Face also supports triggering third-party applications.
- Open QVR Pro.
- Open Event Management.
- Add a rule.
- Click + to add the first rule, or click Add to add additional rules.
- Specify a name and a description for the rule.
- Specify a schedule.
- Click Next.
- Add an event.
- Under If, click Add.
- Specify a name for the event.
- Under Type, select Event URL.
- Specify a source name.
- Copy the event URL for later use.
- Click OK.
- Add an action.
- Under Then, click Add.
- Specify a name for the action.
- Under Type, select Alarm Output.
Note: QVR Pro utilizes the Alarm Output function to trigger the camera's digital output.
- Click OK.
- Click Next.
- Click Finish.
Note: If you are not using QVR DoorAccess, skip step 6.
- Configure QVR DoorAccess.
Note: For a simpler configuration, see Add a Door to select the doors you want to access, then Add or Import Users to specify user information, and then Add an Access Rule to specify whether a user can access certain doors.
| Tasks | Steps |
| Add a Controller (Optional) | See Adding a Controller. |
| Add a Door | Select the doors you want to access with QVR DoorAccess. -
Open QVR DoorAccess and then go to Doors. -
Click Add Door. -
Specify the door name. -
Click Action, and then enter the URL names and URLs from step 4.e for trigger actions. -
Click OK. |
| Add or Import Users | Select users and configure their access rights to specific doors. See Adding a User and Importing a User. |
| Add an Access Rule | See Adding a Door Access Rule. |
| Save an Event Link | Go to Doors. -
Click . -
Copy the event URL for later use. |
- Go to QVR Face.
- Go to Overview.
- Select a live analytics task.
- Click
. - Specify the event name.
- Paste the event URL from Save an Event Link.
Note: If you skipped step 6, paste the event URL from step 4.e.
- Select Profile name.
- Click Select all.
- Click Apply.
QVR Face creates an event rule.
