Get licenses for advanced features from our Software Store.
You can add a USB camera to QVR Pro. This allows you to build a surveillance system on a more affordable budget.
QTS downloads the QVR Pro installer.
The QVR Pro Initial Setup window opens.
QTS installs QVR Pro and a confirmation message appears.
Button | Description |
+ | Click to add your first recording space. |
Add | Click to add more recording spaces. |
Field | Task |
Name | Specify a name for the recording space. Note: Name requirements:
Overwrite Trigger Threshold | Select the overwrite trigger threshold. Note: QVR Pro starts overwriting the oldest recording data when the percentage of used recording space exceeds the specified threshold. |
QTS installs QUSBCam2.
+ | Click to add your first camera. |
Add | Click to add more cameras. |
The Camera Selection screen appears.
You can click Test to verify the camera connection.
You can configure the streaming and recording settings at a later time.
The USB camera is successfully added to QVR Pro.
Welcome! You can start using a variety of QNAP member services.
