What is the cost of using myQNAPcloud Storage to store very small files (less than 4 KB)?
myQNAPcloud Storage / myQNAPcloud Object
Explanation
If you use myQNAPcloud Storage/One to store files that are less than 4 kilobytes (KB) in size, you should be aware that myQNAPcloud Storage's minimum supported file size is 4 KB from a charging perspective. Similarly, you can store files smaller than 4 KB with Wasabi, but you will be charged as if it were a 4 KB file. This policy is comparable to the minimum capacity charge per file/object policies in use by some AWS storage classes (for example, AWS S3 IA has a minimum capacity charge of 128 KB).
