[Thông báo bảo mật quan trọng] Phát hiện các trang web giả mạo Qfinder Pro. Tìm hiểu thêm >
NAS Recovery Guide for TS-855eU and TS-x88ATX series
Last modified date: 2026-04-08
  • TS-855eU, TS-855eU-RP
  • TVS-AIh1688ATX
Overview
NAS Recovery Requirements
  • An empty USB drive of at least 8 GB capacity
  • A Windows PC
Recovering The NAS
You can recover your NAS by first creating a USB boot drive to restore basic NAS functionality and then updating the firmware with Qfinder Pro. If any part of the recovery process fails, see Further Troubleshooting below. To recover your NAS, perform the following steps:
Create a USB boot drive
  1. Download Rufus.
  2. Download the NAS system images below corresponding to the NAS model:
  3. Open Rufus.
  4. Under Device Properties > Boot Selection, click Select.
  5. Select the downloaded NAS system image for TS-885eU / TS-885eu-RP.
  6. Click Open.
  7. Click Start.
    Rufus formats the USB drive and installs the NAS system image onto the USB drive.
    Warning
  1. Power off the NAS.
  2. Remove all drive trays.
  3. Connect the USB boot drive to a rear USB port of the NAS.
  4. Power on the NAS.
    The NAS starts recovering the firmware with the USB boot drive. It will take around 10 minutes to complete the recovery process. Once it is done, the NAS pows off automatically. If the NAS does not power off after 15 minutes, the recovery process has failed. You can try it again or you may contact QNAP technical support.
  5. After the NAS firmware process is finished, remove the USB boot drive from the NAS.
  6. Power on the NAS.
  2. Open Qfinder Pro.
    Tip
  4. Right click on your NAS.
  5. Select Update Firmware.
  7. Click Start.
Install hard drives
  1. After the firmware is updated, perform the following steps to install hard drives:
    4. If the hard drives are new, you can continue to initialize the NAS. For initializing QTS or QuTS hero on your NAS, see the following:
      2. QTS Initialization (5.0.x)
Further Reading
Firmware Recovery Guide
Để được hỗ trợ thêm, hãy hỏi những người dùng khác và chuyên gia QNAP trong cộng đồng. Đến Cộng đồng QNAP
Chọn thông số kỹ thuật
      Xem thêm Thu gọn
      Chọn quốc gia hoặc khu vực của bạn
      Trò chuyện với chúng tôi! Trò chuyện với chúng tôi!
