[Aviso importante de seguridad] Se han detectado sitios web falsos de Qfinder Pro. Más información >
TS-869 Pro Specification
CPU Intel® Atom™ 2.13GHz Dual-core Processor
DRAM 1GB RAM (Expandable RAM, up to 3GB)
NOTE:
1. The system memory can be increased to 3GB by installing an additional 1GB/2GB SO-DIMM RAM module.
2. For the information of RAM module installation and compatible NAS models, please refer to the QNAP RAM Module Installation Guide
Flash Memory 512MB DOM
Hard Disk Drive 8 x 3.5" or 2.5" SATA 6Gb/s, SATA 3Gb/s hard drive or SSD
NOTE:
1. The system is shipped without HDD.
2. For the HDD compatibility list, please visit Compatibility list.
Hard Disk Tray 8 x Hot-swappable and lockable tray
Porta LAN 2 x Gigabit RJ-45 Ethernet port
LED Indicators Status, LAN, USB, eSATA, Power, HDD 1, HDD 2, HDD 3, HDD 4, HDD 5, HDD 6, HDD 7, HDD 8
USB 2x USB 3.2 Gen 1 port (Back: 2)
5x USB 2.0 port (Front: 1; Back: 4)
Support USB printer, pen drive, USB hub, and USB UPS etc.
eSATA 2 x eSATA port (Back)
Buttons System: Power button, USB One-Touch-Backup Button, Reset button
LCD panel Mono-LCD display with backlight
Enter button, Select button for configuration
Alarm Buzzer System warning
Form Factor Tower
Dimensions 185.2 (H) x 298.2 (W) x 235.4 (D) mm
7.29 (H) x 11.74 (W) x 9.27 (D) inch
Weight Net weight: 7.3 kg (16.08 lbs)
Gross weight: 8.6 kg (18.94 lbs)
Sound Level (dB) HDD sleep: 18.7 dB
In operation: 27.5 dB
(with 8 x 500GB HDDs installed)
Power Consumption (W) Sleep mode: 30W
In Operation: 59W
Power-off (in WOL mode): 1W
(with 8 x 1.5TB HDD installed)
Temperature 0-40˚C
Humidity 5~95% RH non-condensing, wet bulb: 27˚C.
Power Supply Input: 100-240V AC, 50/60Hz, Output: 350W
Secure Design K-lock security slot for theft prevention
VGA Reserved VGA interface for maintenance
HDMI™ v1.3
IR Receiver Compatible with either QNAP RM-IR001 or MCE remote controls
Fan 2 x quiet cooling fan (12 cm, 12V DC)
Nota: Utilice sólo módulos de memoria QNAP para mantener el rendimiento y la estabilidad del sistema. Para dispositivos NAS con más de una ranura de memoria, utilice módulos QNAP con especificaciones idénticas y consulte el manual de usuario de hardware para instalar módulos de memoria QNAP compatibles.
Advertencia: Usar módulos no compatibles puede degradar el rendimiento, provocar errores o impedir el arranque del sistema operativo.
QNAP se reserva el derecho de sustituir piezas parciales o accesorios si las piezas originales ya no está disponibles en los fabricantes/proveedores. Cualquier reemplazo será totalmente probado y verificado para cumplir con las estrictas directrices de compatibilidad y estabilidad, y garantizará un rendimiento idéntico al de la pieza original.
Las imágenes de producto son para fines ilustrativos y pueden diferir del producto real Debido a diferencias en los monitores, los colores de los productos también pueden parecer distintos de los que se muestra en el sitio.
Los diseños y las especificaciones están sujetos a modificaciones sin previo aviso.
Operating System
Embedded Linux
Disk Management
  1. Single Disk, JBOD, RAID 0, 1, 5, 5 + Hot Spare, 6, 6 + Hot Spare, 10, 10 + Hot Spare
  4. Global Hot Spare Drive (4-bay NAS and above)
  5. RAID Recovery
  6. Bitmap Support
Supported Clients
  1. Apple Mac OS 10.7 or later
  2. Linux and UNIX
iSCSI (IP SAN)
  1. iSCSI Target
    • Multi-LUNs per Target
    • Supports MPIO & MC/S
    • Stack Chaining Master
  2. Mozilla Firefox 8, 9, 10
  3. Apple Safari 4, 5
  4. Google Chrome
  1. Supports VMware vSphere
  2. Supports Citrix XenServer
Multilingual Support
Power Management
  1. Wake on LAN
File System
  1. Internal Hard Drive: EXT3, EXT4
Access Right Management
  1. Max No. of Users: 4,096
  2. Max No. of User Groups: 512
  3. Max No. of Network Shares: 512
  4. Batch Users Creation
  5. Import/Export Users
  6. User Quota Management
  7. Subfolder Permissions Support for CIFS/SMB, AFP, FTP and Web File Manager
Networking
    • Failover
    • Multi-IP Settings
  4. Virtual LAN (VLAN)
  5. DHCP Client, DHCP Server
  7. UPnP & Bonjour Discovery
  8. USB Wi-Fi Adapter Support
  2. LDAP Server
  3. LDAP Client
  4. Domain Users Login via CIFS/SMB, AFP, FTP, and Web File Manager
Backup Solution
    • Works as Both RTRR Server & Client with Bandwith Control
MyCloudNAS Service
  4. MyCloudNAS Connect for Easy Connection (Windows utility)
Security
  1. IP Filter and Policy-based Automatic IP Blocking
  3. Encrypted Access: HTTPS, FTP with SSL/TLS (Explicit), SSH/SFTP (admin only), Encrypted Remote Replication between QNAP NAS Servers (Rsync over SSH)
  5. Antivirus Protection
  6. FIPS 140-2 Validated AES 256-bit Volume-based Data Encryption*
  8. Importable SSL Certificate
  9. Instant Alert via E-mail, SMS, Instant Messaging (Windows Live), Beep, and LCD Panel
Storage Plug & Play
  • Windows Software: QNAP Finder
  • Create and Map Shared Folders
  • Create and Connect to iSCSI Target/LUN
Web Administration
  1. AJAX-based User Interface
  2. Smart Fan Control
  3. Dynamic DNS (DDNS)
  4. SNMP (v2 & v3)
  5. Resource Monitor
  6. Network Recycle Bin for File Deletion via CIFS/SMB and AFP
  7. Comprehensive Logs (Events & Connection)
  8. Syslog Client
  9. Firmware Live Update
  10. System Settings Backup and Restore
  11. Restore to Factory Default
Powerful All-in-one server
  2. Shared Folder Aggregation (CIFS/SMB)
  3. Web File Manager
    • Supports ISO Mounting
  1. Supported File Formats:
    • Photo: BMP, JPG, JPE, PNG, TGA, GIF, and more.
    • Video: API, MP4, and more.
  7. Photo Sharing by Email
  3. FXP Supported
  6. Unicode Support
  1. Plays or Shares Music Collections with Web Browser
  2. Automatic Classification via Media Library
  3. Supported audio format: MP3, FLAC, OGG, WAV, AIF, AIFF, and more.
    * DRM encryption format is not supported.
  4. Internet Radio (MP3)
  5. Up to 8 Music Alarms
Backup Server
  3. Apple Time Machine Support
  2. BT Download
    • Scheduled Download
    • Configurable Port Range
    • Bandwidth Control
    • UPnP NAT Port Forwarding
    • Selectable Download Files
  3. HTTP/ FTP Download
    • RapidShare Download Support
    • For Both Windows & Mac OS
Web Server
  1. HTTP/HTTPS Connections
  2. Supports WebDAV Connection
  4. Importable SSL Certificate
Surveillance Station
  1. Max. IP Cameras: 16, optional purchase (2 free license included, supported network cameras)
  2. Mobile app: Vmobile (iOS & Android)
Database Server
  1. Built-in MySQL Server (v5.1.36)
Antivirus
  4. Scanning
Print Server
  1. Max No. of Printers: 3
  1. Supports 4 IP Cameras (Optional Purchase) for Network Surveillance
  2. Supports 1 Webcam via QPKG Add-on: QUSBCam
Syslog Server
  2. Immediate E-mail Alerts
  3. Supports Log Filtering
Antivirus
  4. Scanning
RADIUS Server
QPKG Center
  1. Expands Application Services by Easy Online Installation
  2. A Wide Variety of Official and Community QPKG Add-ons
 The actual available QPKGs may vary depending on the NAS platform.
  • Business
    • eyeOS
    • GLPI
    • Squid Proxy Server
    • Vtiger CRM
  • CMS
    • Gallery
    • Joomla!
    • WordPress
    • Xoops
  • Communications
    • Asterisk
    • XMail
    • Xeams
  • Download
    • MLDonkey
    • NZBGet
    • pyLoad
    • SABnzbdplus
    • Transmission
  • Entertainment
    • IceStation
    • Plex Media Server
    • PS3 Media Server
    • Squeezebox Server
  • Utilities
    • iStat
    • Optware IPKG
    • phpMyAdmin
    • Piwik
  • Misc.
    • Java Runtime Environment
    • Mono
    • Python
    • QUSBCam
    • Tomcat
           … and more.
VPN Server
  3. Max No. of Clients: 30
UPnP Media Server
  1. Built-in TwonkyMedia Server
  2. Real-time & Background Photo Transcoding
  3. Supports UPnP Media Player Such as PlayStation 3 and Xbox 360
  4. Supported format (The actual playback capabilities may vary depending on the UPnP client.)
    • Audio: MP3、FLAC、OGG、WAV、AIF、AIFF and more.
    • Playlist: M3U, M3U8, WPL, PLS
DLNA Server
  1. Supports DLNA/UPnP TVs and Players such as PlayStation 3 and Xbox 360
  2. Supported audio format: MP3, FLAC, OGG, WAV, AIF, AIFF, and more.
    *DRM encryption format is not supported.
  3. Support CUE indexing file for APE, FLAC audio format.
  4. Video and Audio On-the-fly Transcoding
* The data encryption functions may not available in accordance to the legislative restrictions of some countries.
**Applies to firmware 3.6.3. Users can purchase activation licenses online and increase the number of channels supported.
TS-869 Pro CD-ROM Ethernet cable x 2
Quick installation guide Flat head screw x 24 (for 2.5" HDD) Flat head screw x 32 (for 3.5" HDD)
Hard disk lock x 1 Power cord
Accesorios opcionales
Los accesorios suministrados junto con el producto, como las tarjetas de expansión, el adaptador de corriente y los accesorios, están cubiertos por una garantía de un año.
Elija especificación
      Mostrar más Mostrar menos
