TS-439 Pro II+ Specification
| CPU | Intel Atom 1.8GHz Single-core Processor |
| DRAM | 1GB RAM |
| Flash Memory | 512MB DOM |
| HDD | 4 x 2.5"/3.5" SATA NOTE:
| HDD Tray | 4 x Hot-swappable and lockable tray |
| LAN Port | 2 x Gigabit RJ-45 Ethernet port |
| LED Indicators | Status, LAN, USB, eSATA, Power, HDD 1, HDD 2, HDD 3, HDD 4 |
| USB | 5 x USB 2.0 port (Front: 1; Back: 4) Support USB printer, pen drive, USB hub, and USB UPS etc. |
| eSATA | 2 x eSATA port (Back) |
| Buttons | System: Power button, USB One-Touch-Backup Button, Reset button |
| LCD panel | Mono-LCD display with backlight Enter button, Select button for configuration |
| Alarm Buzzer | System warning |
| Form Factor | Tower |
| Dimensions | 177 (H) x 180 (W) x 235 (D) mm 6.97 (H) x 7.09 (W) x 9.25 (D) inch |
| Weight | Net weight: 3.65 kg (8.04 lbs) Gross weight: 4.65 kg (10.24 lbs) |
| Sound Level (dB) | w/o HDD installed: 29.1 dB Stand by: 36.9 dB In operation: 37.3 dB (with 4 x 500GB HDD installed) |
| Power Consumption (W) | Sleep mode: 23W In Operation: 33W Power-off (in WOL mode): 1W (with 4 x 500GB HDD installed) |
| Temperature | 0~40˚C |
| Humidity | 0~95% R.H. |
| Power Supply | Input: 100-240V AC, 50/60Hz, Output: 250W |
| Secure Design | K-lock security slot for theft prevention |
| VGA | Reserved VGA interface for maintenance |
| Fan | 1 x quiet cooling fan (9 cm, 12V DC) |
Nota: Utilice sólo módulos de memoria QNAP para mantener el rendimiento y la estabilidad del sistema. Para dispositivos NAS con más de una ranura de memoria, utilice módulos QNAP con especificaciones idénticas y consulte el manual de usuario de hardware para instalar módulos de memoria QNAP compatibles.
Advertencia: Usar módulos no compatibles puede degradar el rendimiento, provocar errores o impedir el arranque del sistema operativo.
QNAP se reserva el derecho de sustituir piezas parciales o accesorios si las piezas originales ya no está disponibles en los fabricantes/proveedores. Cualquier reemplazo será totalmente probado y verificado para cumplir con las estrictas directrices de compatibilidad y estabilidad, y garantizará un rendimiento idéntico al de la pieza original.
Las imágenes de producto son para fines ilustrativos y pueden diferir del producto real Debido a diferencias en los monitores, los colores de los productos también pueden parecer distintos de los que se muestra en el sitio.
Los diseños y las especificaciones están sujetos a modificaciones sin previo aviso.
Powerful All-in-one server |
Los accesorios suministrados junto con el producto, como las tarjetas de expansión, el adaptador de corriente y los accesorios, están cubiertos por una garantía de un año.
