TS-269 Pro Specification
CPU Intel® Atom 2.13GHz Dual-core Processor
DRAM 1GB RAM (Expandable RAM, up to 3GB)
NOTE:
1. The system memory can be increased to 3GB by installing an additional 1GB/2GB SO-DIMM RAM module.
2. For the information of RAM module installation and compatible NAS models, please refer to the QNAP RAM Module Installation Guide
Flash Memory 512MB DOM
Hard Disk Drive 2 x 3.5" or 2.5" SATA 6Gb/s, SATA 3Gb/s hard drive or SSD
NOTE:
1. The system is shipped without HDD.
2. For the HDD compatibility list, please visit www.qnap.com/compatibility.
Hard Disk Tray 2 x Hot-swappable and lockable tray
Porta LAN 2 x Gigabit RJ-45 Ethernet port
LED Indicators Status, LAN, USB, eSATA, Power, HDD 1, HDD 2
USB 2 x USB 3.2 Gen 1 port (Back: 2)
3 x USB 2.0 port (Front: 1; Back: 2)
Support USB printer, pen drive, USB hub, and USB UPS etc.
eSATA 1 x eSATA port (Back)
Buttons System: Power button, USB One-Touch-Backup Button, Reset button
Alarm Buzzer System warning
Form Factor Tower
Dimensions 150 (H) x 102 (W) x 216 (D) mm
5.91 (H) x 4.02 (W) x 8.5 (D) inch
Weight Net weight: 1.74 kg (3.84 lbs)
Gross weight: 2.92 kg (6.44 lbs)
Sound Level (dB) HDD sleep: 18.5 dB
In operation: 20.4 dB
(with 2 x 500GB HDDs installed)
Power Consumption (W) Sleep mode: 16W
In Operation:25W
Power-off (in WOL mode): 1W
(with 2 x 1TB HDD installed)
Temperature 0-40˚C
Humidity 5~95% RH non-condensing, wet bulb: 27˚C.
Power Supply Input: 100-240V AC, 50/60Hz, Output: 90W
Secure Design K-lock security slot for theft prevention
HDMI™ v1.3
IR Receiver Compatible with either QNAP RM-IR001 or MCE remote controls
Fan 1 x quiet cooling fan (7 cm, 12V DC)
Nota: Utilice sólo módulos de memoria QNAP para mantener el rendimiento y la estabilidad del sistema. Para dispositivos NAS con más de una ranura de memoria, utilice módulos QNAP con especificaciones idénticas y consulte el manual de usuario de hardware para instalar módulos de memoria QNAP compatibles.
Advertencia: Usar módulos no compatibles puede degradar el rendimiento, provocar errores o impedir el arranque del sistema operativo.
QNAP se reserva el derecho de sustituir piezas parciales o accesorios si las piezas originales ya no está disponibles en los fabricantes/proveedores. Cualquier reemplazo será totalmente probado y verificado para cumplir con las estrictas directrices de compatibilidad y estabilidad, y garantizará un rendimiento idéntico al de la pieza original.
Las imágenes de producto son para fines ilustrativos y pueden diferir del producto real Debido a diferencias en los monitores, los colores de los productos también pueden parecer distintos de los que se muestra en el sitio.
Los diseños y las especificaciones están sujetos a modificaciones sin previo aviso.
Operating System
QNAP Turbo NAS System 3.7
iSCSI (IP SAN)
  1. iSCSI Target
    • Multi-LUNs per Target
    • Supports MPIO & MC/S
    • Stack Chaining Master
Supported Clients
  1. Apple Mac OS 10.7 or later
  2. Linux and UNIX
  1. Supports VMware vSphere
  2. Supports Citrix XenServer
  2. Mozilla Firefox 8+
  3. Apple Safari 4+
  4. Google Chrome
Power Management
  1. Wake on LAN
Multilingual Support
Access Right Management
  1. Max No. of Users: 4,096
  2. Max No. of User Groups: 512
  3. Max No. of Network Shares: 512
  4. Batch Users Creation
  5. Import/Export Users
  6. User Quota Management
  7. Subfolder Permissions Support for CIFS/SMB, AFP, FTP and Web File Manager
File System
  1. Internal Hard Drive: EXT3, EXT4
  2. LDAP Server
  3. LDAP Client
  4. Domain Users Login via CIFS/SMB, AFP, FTP, and Web File Manager
Networking
    • Failover
    • Multi-IP Settings
  4. Virtual LAN (VLAN)
  5. DHCP Client, DHCP Server
  7. UPnP & Bonjour Discovery
  8. USB Wi-Fi Adapter Support
MyCloudNAS Service
  4. MyCloudNAS Connect for Easy VPN Connection (Windows utility)
Backup Solution
    • Works as Both RTRR Server & Client with Bandwith Control
Storage Plug & Play
  1. Windows Software: QNAP Finder
  2. Create and Map Shared Folders
  3. Create and Connect to iSCSI Target/LUN
Security
  1. IP Filter and Policy-based Automatic IP Blocking
  3. Encrypted Access: HTTPS, FTP with SSL/TLS (Explicit), SSH/SFTP (admin only), Encrypted Remote Replication between QNAP NAS Servers (Rsync over SSH)
  5. Antivirus Protection
  6. FIPS 140-2 Validated AES 256-bit Volume-based Data Encryption*
  8. Importable SSL Certificate
  9. Instant Alert via E-mail, SMS, and Beep
Web Administration
  1. AJAX-based User Interface
  2. Smart Fan Control
  3. Dynamic DNS (DDNS)
  4. SNMP (v2 & v3)
  5. Resource Monitor
  6. Network Recycle Bin for File Deletion via CIFS/SMB and AFP
    • Automatic Cleanup
    • File Type Filter
  7. Comprehensive Logs (Events & Connection)
  8. Syslog Client
  9. Firmware Live Update
  10. System Settings Backup and Restore
  11. Restore to Factory Default
  12. Mobile App Qmanager for Remote Monitoring
Disk Management
  1. Single Disk, JBOD, RAID 0, 1, 5, 6, 10, 5+hot spare
  4. RAID Recovery
  5. Bitmap Support
Powerful All-in-one server
  2. Windows ACL
  3. Advanced Folder Permission for SMB, AFP, FTP, Web File Manager
  4. Shared Folder Aggregation (CIFS/SMB)
  5. Web File Manager
    • Supports ISO Mounting
  6. Mobile App: Qfile for File Browsing and Management
  1. Supported File Formats:
    • Photo: BMP, JPG, JPE, PNG, TGA, GIF, and more.
    • Video: API, MP4, and more.
  7. Photo Sharing by Email
  3. FXP Supported
  6. Unicode Support
  1. Plays or Shares Music Collections with Web Browser
  2. Automatic Classification via Media Library
  3. Supported audio format: MP3, FLAC, OGG, WAV, AIF, AIFF, and more.
    * DRM encryption format is not supported.
  4. Internet Radio (MP3)
  5. Up to 8 Music Alarms
Backup Server
  3. Apple Time Machine Support
  2. BT Download
    • Supports Magnet Links
    • Scheduled Download
    • Configurable Port Range
    • Bandwidth Control
    • Selectable Download Files
  3. HTTP/ FTP Download
    • RapidShare Download Support
    • For Both Windows & Mac OS
Web Server
  1. HTTP/HTTPS Connections
  2. Supports WebDAV Connection
  4. Importable SSL Certificate
Antivirus
  4. Scanning
Database Server
  1. Built-in MySQL Server
Print Server
  1. Max No. of Printers: 3
Syslog Server
  2. Immediate E-mail Alerts
  3. Supports Log Filtering
RADIUS Server
  2. Supports PAP, EAP-TLS/PAP, and EAPTTLS/PAP Authentication
TFTP Server with PXE Booting
VPN Server
  3. Max No. of Clients: 30
Surveillance Station
  1. Max. IP Cameras: 16, optional purchase (2 free license included, supported network cameras)
  2. Mobile app: Vmobile (iOS & Android)
*The data encryption functions may not available in accordance to the legislative restrictions of some countries.
TS-269 Pro CD-ROM Ethernet cable x 2
Quick installation guide Flat head screw x 8 (for 3.5" HDD) Flat head screw x 6 (for 2.5" HDD)
Hard disk lock x 1 Power cord Adaptor
Accesorios opcionales
Los accesorios suministrados junto con el producto, como las tarjetas de expansión, el adaptador de corriente y los accesorios, están cubiertos por una garantía de un año.
Elija especificación
      Mostrar más Mostrar menos
