QNA-T310G1T Specification
Single-port Thunderbolt 3 to single-port 10GbE NBASE-T RJ-45 (Legacy)
Hálózati adapterek Thunderbolt – 10GbE Alapértelmezett garancia 2 év PHY IC AQC107S I/O 1 x Thunderbolt 3, 1 x 10GbE/NBASE-T csatlakozó Átvitel sebességek 10Gbps/5Gbps/2.5Gbps/1Gbps/100Mbps Működési hőmérséklet -5 - 45 °C (23 - 113°F) Csomag tartalma QNA-T310G1T, 0.5M Thunderbolt 3 cable and manual Port és kábel RJ-45; Cat 6a kábel ajánlott Megjegyzés ● Windows® devices: The driver for the Marvell AQtion AQC107 is required to use the QNA-T310G1T. Click here to download drivers
● Ubuntu: 20.04, 22.04
● QNAP Thunderbolt™ 3 NAS: Requires QTS 4.3.6 (or later).Note: QNAP reserves the right to replace partial parts or accessories if the original is no longer available from its manufacturer/supplier. Any replacement would be fully tested and verified to meet strict compatibility and stability guidelines and will deliver identical performance to the original.
