QNA-UC10G1T
USB 4 Type-C to 10GBASE-T RJ45 Network Adapter, Compatible with USB 4 and Thunderbolt™ 3/4 Ports
qna-uc10g1t
Enjoy stable 10GbE high-speed networking using a USB Type-C connection to greatly enhance work efficiency, even on computers without built-in network ports.
  • Broad interface compatibility
    The QNA-UC10G1T includes a 1-meter USB 4 cable for connecting to your computer's USB 4 or Thunderbolt™ 3/4 ports.
    ● Windows: Compatible with USB 4 and Thunderbolt™ 4 ports.
    ● macOS: Compatible with Thunderbolt™ 4 and Thunderbolt™ 3 ports.
  • Multi-system compatibility
    Supports Windows®, macOS®, and Linux® computers (driver installation required).
    Not compatible with Windows® OS running on ARM-based processors.
  • Multi-speed support
    Compatible with various network environments through Multi-Gigabit support for 10/5/2.5/1 GbE.
  • Low-noise operation
    Fanless design ensures stable performance with reduced noise and maintenance, offering a quiet, reliable experience for long-term use.
Add 10GbE high-speed network connectivity
Connect your devices to a 10GbE network with the QNA-UC10G1T and significantly boost your transmission performance and team productivity.
Please note:
1. QNA Series adapters will not work when connected using a Thunderbolt 2 to Thunderbolt 3 adapter.
2. To ensure optimal performance, it is recommended to set the Jumbo Frames on all the devices in your local network environment to MTU 9000 and switch the power mode to High Performance. How to set the MTU >
  • SMB Throughput 1MB (1 x 10GbE)
    Read
    1,181 MB/s
    Write
    1,181 MB/s
  • Windows File Transfer (1 x 10GbE)
    Download
    1,172 MB/s
    Upload
    1,172 MB/s
NAS: TBS-h574TX-i5-16G
NAS O.S.: QuTS hero h5.1.6.2735
SSD: 5 x Samsung 960 PRO 1TB, Raid 5
Thunderbolt: 2 x Thunderbolt 4, MTU 9000
Client PC: Intel i7-6700 3.4GHz, 64GB RAM, LAN-10G2T-X550, Windows Server 2019, MTU 9000
IOmeter: RAM*4, 30-sec ramp up time, 3-min seq. run time, 1 worker, 32-outstanding
Stylish metal finish and portable
Perfectly fits in with all your tech gear
Enjoy network upgrades anywhere with doubled efficiency
  • Creative Professionals
    YouTubers, video editors, or game developers can accelerate their workflows by processing large files or assets faster.
  • Multimedia Entertainment
    Seamlessly stream HD videos or games to ensure smooth playback without buffering.
  • Office Operations
    Speed up file transfers and sharing and ensure smooth remote meetings and cloud backups for uninterrupted task execution.
Build a high-speed network environment with a 10GbE switch
In multi-user, multi-device environments, connect your computer to a QNAP 10GbE switch using the QNA-UC10G1T network adapter to create a high-bandwidth, high-speed collaborative network across multiple connected devices.
Explore enterprise high-speed networking solutions >
Easy setup, instant connection
Simply connect a QNA-UC10G1T to your Mac® or Windows® computer using the included USB 4 cable, and connect the adapter to a 10GbE switch, NAS, or other 10GbE device using an RJ45 Cat 5e, Cat 6, Cat 6a (or above) cable.
● Windows® devices: The driver for the Marvell AQtion AQC113 is required to use the QNA-UC10G1T. Click here to download drivers
● Mac® devices: Supports macOS 12.7 to 15.4.
● Ubuntu devices: Supports Ubuntu 22.04_kernel 6.5.0-41. The driver for the Marvell AQtion AQC113 is required to use the QNA-UC10G1T. Click here to download drivers
How to set the MTU
Note: When connecting to a network switch, please ensure the Jumbo Frame on the port is also set to 9000 (MTU size).
MacOS:
1. Open System Settings and go to Network.
2. Select QNA Thunderbolt Ethernet and click Details.
3. Go to Hardware, change Configure to Manually, and set MTU to Jumbo (9,000).
Windows:
1. Open Settings and go to Network & Internet.
2. Click Change your adapter options, right click the QNA adapter and click Properties.
3. Click Configure, go to the Advanced tab, select Jumbo Frame and set the value to 9KB MTU.
NAS:
1. Open Network & Virtual Switch
2. Go to Interfaces and find the Ethernet adapter on the Adapter List.
3. Open the adapter menu and select Configure.
4. Go to the IPv4 tab and set Jumbo Frame to 9000.
Need help?
