[Aviso Importante de Segurança] Sites falsos do Qfinder Pro detectados. Saiba mais >
Storage & Snapshots Quick Start Guide for QTS
Data da última modificação: 2025-01-09
  • What is Storage & Snapshots?
  • System requirements
  • Before you start
  • Create storage space in 3 steps
    • Step 1: Create a storage pool with RAID
    • Step 2: Create a system volume
    • Step 3: Create a shared folder
  • Manage your storage
    • Manage disks
    • Manage storage units
  • Protect your data
    • Take snapshots
    • Back up your data
  • Improve your read/write performance
    • Cache acceleration
    • Qtier
This guide is applicable to QTS 5.1.0 or later.
Storage & Snapshots is a built-in utility in QTS for creating, managing, and monitoring storage space on your QNAP NAS.
After initializing your NAS, you'll need to create some storage space in Storage & Snapshots so that you can store data, install applications, and fully utilize all the available functions in QTS.
Learn more about the storage architecture and storage units in QTS.
Note
For the QuTS hero version of this guide, see Storage & Snapshots Quick Start Guide for QuTS hero.
System requirements
Operating system: QTS
Before you start
Make sure you meet the following requirements before creating your first storage units in Storage & Snapshots:
  • Prepare disks.
    • Use compatible disks. For details, see Compatibility List.
    • Back up any existing data on your disks before initializing the NAS or creating a RAID group.
    • When creating a RAID group, for best performance use disks of the same brand, capacity, and disk type (all HDD, all SSD, or all SAS).
      Note
      If you mix disks in a RAID group, all disks will function according to the speed of the slowest disk and the capacity of the smallest disk.
  • You have initialized your NAS and installed QTS.
  • You are logged in as an administrator.
  • Make sure your installed disks have the following statuses in Storage & Snapshots > Storage > Disks/VJBOD > Disks:
    • Health Status: Good
    • Status: Ready
    • Used Type: Free
Before your NAS can start storing data, you must create a volume to serve as the system volume. We recommend creating a storage pool and then creating a thick volume in the pool. After that, you can install applications and create shared folders.
  1. Open Storage & Snapshots and go to Storage > Storage/Snapshots.
  2. Click New Storage Pool to open the Create Storage Pool Wizard.
  3. Click Start, and then click Next.
  4. Select disks to include in your storage pool.
    Note
    To prevent data loss due to disk failure, we recommend selecting at least two disks so that you can select RAID 1 or above for the RAID type.
  5. Optional: Under Mode, configure one or more disks to serve as spare disks.
    Note
    A spare disk allows your system to automatically replace a faulty disk in a RAID group. The system can then rebuild the RAID group so that it regains its data protection capability as soon as possible.
  6. Optional: Select a different RAID type.
    The system automatically selects the most optimized RAID type based on the disks selected.
    For details on RAID types, see QTS RAID type comparison.
  7. Follow the remaining steps in the wizard.
    For details on configuration options, see Creating a storage pool in the QTS User Guide.
After your first storage pool is created, create a system volume in the pool.
  1. Open the Volume Creation Wizard using one of the following methods:
    • Click New Volume on the pop-up message you saw after creating your first storage pool.
    • Open Storage & Snapshots, go to Storage > Storage/Snapshots, and then click Create > New Volume.
      The Volume Creation Wizard opens.
  2. Select Thick volume.
    Note
    • The system volume must be a thick volume or a static volume. For most storage scenarios, we recommend a thick volume.
    • For a detailed comparison of the different volume types, see Thick, thin, and static volumes in the QTS User Guide.
  3. Click Next.
  4. Follow the remaining steps in the wizard.
    For details on configuration options, see Creating a thick or thin volume in the QTS User Guide.
After your system volume is created, you can install applications, create other volumes (thick or thin) to divide your storage space, and create shared folders for storing and sharing files.
QTS automatically creates some default shared folders in the system volume. You can create additional shared folders to organize your files and configure different permission settings for each folder.
  1. Open Control Panel and go to Privilege > Shared Folders > Shared Folder.
  2. Click Create, and then select Shared Folder to open the shared folder creation wizard.
  3. Follow the steps in the wizard.
    For details on configuration options, see Creating a shared folder in the QTS User Guide.
Manage your storage
Manage disks
  1. Open Storage & Snapshots and go to Storage > Disks/VJBOD > Disks.
    The screen shows a comprehensive overview of all disks in your system.
  2. Check disk statuses.
    • Click a disk to display additional disk information in the bottom pane.
    • You can also access the Action menu to perform various operations on the disk.
    To learn more, see the Disks section in the QTS User Guide.
    The screen shows a hierarchical view of your storage units, including storage pools, volumes, and LUNs.
  2. Click a storage unit, and then click Manage.
    • The storage unit's management window opens with further details about the storage unit.
    • The management window also includes an Action menu for useful operations such as setting threshold alerts, increasing free space, resizing the storage unit, and more.
To learn more about specific actions you can take on your storage units in Storage & Snapshots, see the following:
Protect your data
Take snapshots
A snapshot protects data by recording the state of a storage unit at a specific point in time. With snapshots, you can:
  • Restore a storage unit to a previous state.
  • Access and restore previous versions of files and folders.
  • Create an identical copy of a storage unit.
For details, see FAQs about snapshots and the Snapshots section in the QTS User Guide.
Back up your data
We recommend using the 3-2-1 strategy to back up your data: Keep three total copies of your data, store two copies on different media, and store one copy off-site.
QNAP provides a native backup solution with the Hybrid Backup Sync application, which allows you to easily back up data on your NAS to another device or to a cloud storage space. For details, see Hybrid Backup Sync.
Cache acceleration
You can use one or more SSDs to create an SSD cache, which allows you to improve the read and write performance of your NAS.
For details on compatible NAS models and requirements, see SSD Cache Acceleration.
To create an SSD cache in Storage & Snapshots, go to Storage > Cache Acceleration, and click the + button.
For detailed instructions, see Creating the SSD Cache in the QTS User Guide.
Qtier
Qtier is a proprietary technology in QTS that automatically moves infrequently accessed data to slower high-capacity disks for cost effective data storage, and frequently accessed data to the fastest disks for optimal read and write performance.
You can enable and configure Qtier in a storage pool during pool creation.
For details, see the Qtier section in the QTS User Guide.
  • Storage & Snapshots: Official QNAP landing page for Storage & Snapshots
  • Knowledge Base: Searchable database of FAQs, tutorials, and web helps
  • QNAP College: Instruction video tutorials
  • Download Center: Latest firmware files, hardware user guides, and other information available for download
  • Compatibility List: Lists of HDD and SSD models and external devices that are compatible with QNAP devices
  • QTS User Guide: Web help for the latest version of QTS, including a detailed chapter on Storage & Snapshots
Este artigo foi útil?
64% das pessoas acham que foi útil.
Obrigado por seu retorno.
Para obter mais ajuda, pergunte a outros usuários e aos especialistas da QNAP na comunidade. Ir para a Comunidade QNAP
Escolher especificação
      Mostrar mais Menos
