[Aviso Importante de Segurança] Sites falsos do Qfinder Pro detectados. Saiba mais >
Should I use a thin or a thick volume?
Data da última modificação: 2023-12-07
Applicable Products:
  • All NAS series that support Storage Pool
Thick volumes are recommended if you are creating multiple volumes but need to guarantee the space for a particular volume. The performance of a thick volume may also be slightly better than a thin volume in some situations.
Thin volumes are recommended when you need to create multiple volumes and share the storage pool space efficiently between them. Also, thin volumes are recommended if you are planning to use volume snapshots. When using snapshots with thin volumes, only modifications to existing data on the volume will increase the snapshot used space, the size will be the same as the modified data.
For more information, you could refer to the below article:
What is the difference between Static Volume, Thin Volume, and Thick Volume?
Este artigo foi útil?
85% das pessoas acham que foi útil.
Obrigado por seu retorno.
Ainda precisa de ajuda?
Publique sua pergunta na Comunidade QNAP. A equipe da QNAP e usuários experientes irão responder.
Perguntar à Comunidade
Escolher especificação
      Mostrar mais Menos
