Will trunking accelerate transfer speed?
Ultima data di modifica 2022-06-24
Applicable Products:
  • Network&Virtual Switch
Port Trunking can increase bandwidth on a QNAP NAS . Click here for details.
But please note the following:
  1. Port Trunking cannot break the speed limit of a single Ethernet device, but it offers a sufficient amount of bandwidth for multiple users connecting at the same time. For example, if two 1Gb NICs are used for Port Trunking, the aggregated network bandwidth will be increased to 2Gb, but the network speed will remain 1Gb.
  2. Available system resources and the maximum read/write speeds of the storage devices on the NAS will greatly influence the overall bandwidth.
100% delle persone lo ritengono utile.
Grazie per il feedback.
Per ulteriore assistenza, chiedi ad altri utenti e agli esperti QNAP nella community. Vai alla community QNAP
Scegliere le caratteristiche
      Mostra di più Meno
