| Network Adapters | USB 4 to 10GbE |
| Dimensions (L x W x H) | 124 × 56 × 67.27 mm |
| Weight | 0.25kg kg |
| Standard Warranty | 2 year |
| PHY IC | AQC113 |
| I/O | 1 x USB-C, 1 x 10GBASE-T connector |
| Transmission rates | 10Gbps/5Gbps/2.5Gbps/1Gbps/100Mbps |
| Operating temperature | 0-35˚C |
| Package Contents | QNA adapter, 1 x USB 4 C to C cable, manual |
| Port and cable | RJ-45; Cat 6a cable recommended |
