Can I use an UPS connected in another NAS as a network UPS slave?
Last modified date: 2022-06-24
Applied models:
Applied Firmware:
Unfortunately, it is not possible to use an UPS connected in another NAS as a network UPS slave, the current configuration of the QNAP NAS does not support this type of configuration, it is necessary that the UPS can work as a Server with its own IP, so this can be configured properly, please, refer to the link below with further information about how to configure it in the correct way.
Related Document:
Configuring the UPS Settings
33% of people think it helps.
