NAS Recovery Guide for TS-328, TS-x16 series, TS-x28A series, TS-x30 series and TS-x33 series
Data da última modificação: 2026-05-12
Applicable Models
  • TS-128A, TS-228A, TS-328
  • TS-216, TS-216G, TS-416
  • TS-130, TS-230
  • TS-133, TS-233, TS-433
  • TS-433eU
  • TS-AI642
Overview
NAS Recovery Requirements
  • An empty USB drive of at least 4 GB capacity
  • A Windows PC
Recovering The NAS
You can recover your NAS by first creating a USB boot drive to restore basic NAS functionality and then updating the firmware with Qfinder Pro. If any part of the recovery process fails, see Further Troubleshooting below. To recover your NAS, perform the following steps:
Create a USB boot drive
  1. Download the Rufus with this link: https://github.com/pbatard/rufus/releases/download/v3.4/rufus-3.4.exe
  2. Download the NAS system image corresponding to your NAS:
  3. Connect the USB drive to your PC.
  4. Open Rufus.
  5. Under Boot Selection, Click Select.
  6. Select the downloaded NAS system image.
  7. Click Open.
  8. Click Start.
    Rufus formats the USB drive and installs the NAS system image onto the USB drive.
    Warning
Use USB boot drive to recover the NAS
  1. Power off the NAS.
  2. Remove all drive trays.
  3. Connect the USB boot drive to a rear USB port of the NAS.
  4. Power on the NAS with the following steps:
    1. Press and hold the USB One Touch Copy button or reset button.
    2. Press the power button.
    3. Continue holding the USB One Touch Copy button or reset button until a NAS audio alert is triggered.
    4. Release the USB One Touch Copy button or reset button.
  5. If your NAS a TS-128A, TS-228A, TS-328, TS-130, or TS-230 then perform the following:
    1. Wait until one of the following occurs:
      1. A NAS audio alert of 3 short beeps is triggered.
        The NAS firmware recovery process starts.
      2. No audio alert is triggered after waiting 3 minutes.
        The NAS firmware recovery process failed. Repeat steps 4 & 5. If the NAS recovery process is still not successful, see the Further Troubleshooting section below.
    2. Wait for the NAS firmware recovery process to finish.
      When the NAS firmware recovery process is finished a NAS audio alert of one long beep will be triggered and the NAS will automatically shut down.
    3. If a NAS audio alert of two long beeps is triggered, or the NAS does not automatically shut down 5 minutes after the long beep audio alert, then the NAS firmware recovery process was not successful. Repeat steps 4 & 5. If the NAS recovery process is still not successful, see the Further Troubleshooting section below.
  6. If your NAS is a TS-133, TS-233, TS-433, TS-216, TS-216G, TS-416 or TS-AI642 then perform the following:
    1. Wait until the system status LED starts flashing alternate red & green.
    2. When the NAS firmware recovery process is finished, a NAS audio alert of 3 short beeps is triggered.
    3. If the system status LED became solid red and a NAS audio alert of 2 long beeps was triggered during the recovery process, then the NAS recovery process failed. Retry the recovery process by repeating steps 4 & 6. If the NAS recovery process is still not successful, see the Further Troubleshooting section below.
  7. After the NAS firmware process is finished, remove the USB boot drive from the NAS.
  8. Power on the NAS.
  2. Open Qfinder Pro.
    Tip
  4. Right click on your NAS.
  5. Select Update Firmware.
  7. Click Start.
Install hard drives
  1. After the firmware is upated, perform the following steps to install hard drives:
    4. If the hard drives are new, you can continue to initialize the NAS. For initializing QTS or QuTS hero on your NAS, see the following:
      2. QTS Initialization (5.0.x)
Further Reading
Firmware Recovery Guide
Este artigo foi útil?
41% das pessoas acham que foi útil.
Obrigado por seu retorno.
Para obter mais ajuda, pergunte a outros utilizadores e aos especialistas da QNAP na comunidade. Ir para a Comunidade QNAP
Escolher especificação
      Mostrar mais Menos
      Fale connosco! Fale connosco!
