NAS Recovery Guide for x86-based NAS
Data da última modificação: 2025-10-07
Applicable Models
  • TS-251B, TS-251D, TS-451D, TS-451D2, TS-551
  • TS-253B, TS-453B, TS-653B, TS-253Be, TS-453Be, TS-453BT3, TS-453BU, TS-853BU, TS-1253BU
  • TS-453U, TS-853U, TS-1253U, TS-251A, TS-451A, TBS-453A, TBS-453DX, HS-453DX, TS-253D, TS-453D, TS-453DU, TS-653D, TS-253A, TS-453A, TS-653A, TS-853A, TS-453E, TS-253E
  • TS-262, TS-462, TS-264, TS-364, TS-464, TS-664, HS-264, TS-262C, TS-462C, TS-464C, TS-464C2, TS-564
  • TS-466C
  • TVS-463, TVS-663, TVS-863
  • TS-464U, TS-1264U-RP
  • TBS-464
  • TVS-471, TVS-671, TVS-871, TVS-871T, TVS-471U, TVS-871U, TVS-1271U
  • TVS-672N, TVS-872N, TVS-672X, TVS-872X, TVS-472XT, TVS-672XT, TVS-872XT, TVS-872XU, TVS-972XU, TVS-1272XU, TVS-1672XU
  • TVS-473, TVS-673, TVS-873, TVS-675, TS-873U, TS-1273U, TS-1673U
  • TVS-h474, TVS-h674, TVS-h874
  • TBS-h574TX
  • TS-677, TS-877, TS-1277, TS-877XU, TS-977XU, TS-1277XU, TS-1677XU, TS-2477XU, TS-h1277XU, TS-h1677XU, TS-h2477XU
  • TS-1685
  • TVS-ECx80, TVS-ECx80+ series, TVS-ECx80U Series
  • TVS-682, TVS-882, TVS-1282, TVS-682T, TVS-882T, TVS-1282T, TVS-882ST2, TVS-882ST3, TVS-882BR, TVS-882BRT3, TVS-951X, TVS-1282T3, TVS-1582TU, TS-883XU, TS-983XU, TS-1283XU, TS-1683XU, TS-2483XU, TS-h1283XU
  • TDS-16489U
  • TDS-16489U R2
  • TES-1885U, TES-3085U
  • TVS-h1288X, TVS-h1688X, TS-h3088XU, TS-h1886XU-RP_R2
  • TS-h987XU, TS-h1887XU, TS-h2287XU
  • TS-h3087XU
Overview
NAS Recovery Requirements
  • An empty USB drive of at least 4 GB capacity
  • A USB keyboard
  • An HDMI™ cable, or a VGA cable
  • A Windows PC
  • A monitor
Recovering the NAS
You can recover your NAS by first creating a boot disk to restore basic NAS functionality and then updating the firmware with Qfinder Pro. If any part of the recovery process fails, see Further Troubleshooting below. To recover the NAS, perform the following steps:
Prepare the NAS and verify the state of the DOM
  1. Power off the NAS.
  2. Remove all drive trays.
  3. Connect the USB keyboard to a USB port on the NAS.
  4. If the NAS has a VGA or HDMI™ port, connect the NAS to a monitor with a corresponding HDMI™ or VGA Cable.
  5. If the NAS does not have either a VGA or HDMI™ port but does have a console port, then connect the NAS to a monitor via the console port. For details see, How do I enter BIOS and Console with 3.5mm Console port?
  6. Power on the NAS
    BIOS information is displayed including the version and release date of the BIOS.
  7. Wait until the DOM (Disk-on-module) starts up.
    If the DOM fails to start up completely, then the DOM data has been corrupted and you can continue following this guide to recover the NAS.
Create a USB boot drive
  1. Download Rufus.
  2. Download and install the version of Clonezilla that corresponds to the NAS model:
    NAS ModelClonezilla
    • HS-453DX, TS-251D, TS-451D, TS-451D2, TS-551
    • TS-253D, TS-453D, TS-453DU, TS-653D, TS-453E, TS-253E
    • TS-251B, TS-253B, TS-453B, TS-653B, TS-253Be, TS-453Be, TS-453BT3
    • TVS-675, TS-677, TS-877, TVS-951X, TS-1277
    clonezilla-live-2.5.0-25-amd64.iso
    • TS-x77 Series, TS-x77XU Series, TS-h1277XU, TS-h1677XU, TS-h2477XU
    • TS-x83XU Series, TS-h1283XU
    • TS-1685, TES-1885U, TES-3085U
    • TS-h987XU, TS-h1887XU, TS-h2287XU, TS-h3087XU
    clonezilla-live-2.5.0-25-amd64_console.iso
    • TS-hx88X Series, TS-h3088XU
    clonezilla-live-2.7.1-22-amd64.zip
    • TS-262, TS-462, TS-662, TS-264, TS-364, TS-464, TS-664, TS-464U, TS-1264U-RP
    • TS-262C, TS-462C, TS-464C, TS-464C2, TS-564
    • TS-466C
    • TBS-464
    • TBS-h574TX
    clonezilla-live-20221103-kinetic-amd64.iso
    • TS-453BU, TS-853BU, TS-1253BU
    • TS-453U, TS-853U, TS-1253U, TS-251A, TS-451A, TBS-453A, HS-453DX, TS-253A, TS-453A, TS-653A, TS-853A
    • TVS-ECx80 / TVS-ECx80+ series, TVS-ECx80U Series
    • TVS-682, TVS-882, TVS-1282, TVS-682T, TVS-882T, TVS-1282T, TVS-882ST2, TVS-882ST3, TVS-882BR, TVS-882BRT3, TVS-1282T3, TVS-1582TU
    • TDS-16489U
    • TDS-16489U R2
    • TS-h1886XU-RP_R2
    clonezilla-live-2.4.2-10-amd64.iso
  3. Format the USB flash drive as FAT32:
    1. Open File Explorer.
    2. Go to My Computer.
    3. Locate the USB flash drive.
    4. Right click the USB flash drive icon.
      A context menu appears.
    5. Click Format.
      The USB Format window appears.
    6. Under File system, select Fat32.
    7. Click Start.
      A confirmation window appears explaining that all data will be erased on the flash drive.
      Warning
    8. Click OK.
      The USB flash drive is formatted.
  4. Install Clonezilla on the USB drive:
    1. Open Refus.
    2. Under Device, select the USB drive.
    3. Next to Boot selection, click Select.
    4. Select the downloaded Clonezilla ISO file.
    5. Click Open.
    6. Click Start.
      Rufus installs Clonezilla onto the USB drive.
  5. Download one of the NAS system images below corresponding to the NAS model:
  6. Rename the NAS sytem image file to "dom.img"
  7. Copy the NAS system image file to the root folder of USB drive.
Use the USB boot drive to recover the corrupted DOM
  2. Connect the USB boot drive to a USB port on the NAS.
  3. Power on the NAS.
  4. Press the delete key to enter the BIOS page when the enter setup prompt appears on the monitor connected to the NAS.
    The BIOS page appears.
  5. Use arrow keys to navigate to the Boot tab.
  6. Under Boot Option Priorities > Boot Option #1, specify your USB flash drive. If your NAS has UEFI-based BIOS (for example the HS-453DX, TVS-951X, TVS-h1288X, TVS-h1688X, or TS-h3088XU) then select the UEFI version of your USB flash drive.
    Warning
    Do not select USB DISK MODULE.
    Selecting the UEFI version of your USB drive for UEFI-based BIOS:
  7. Use the arrow keys to navigate to the Save & Exit tab.
  8. Under Save Options, select Save Changes and Exit and press enter.
    The NAS will start up using your USB drive, and the Clonezilla options page appears.
  9. Select the Clonezilla boot option:
    1. If your monitor is connected to the NAS via a com port, then select Clonezilla Live (Serial Console).
    2. If your monitor is connected to the NAS via an HDMI™ or VGA cable, then select Clonezilla Live (Default settings, VGA 800x600).
  10. If the Choose language page appears, select your language.
  11. If the Configuring console-data display page appears, select Don't touch keymap.
  12. When the Start Clonezilla page appears, select Enter_shell.
    The Chose mode page appears.
  13. Select cmd.
    An Ubuntu terminal appears.
  14. View NAS partitions by entering the following commands:
    sudo su
    fdisk –l
    The partitions present depend on the NAS model:
    • TS-251A, TS-253E, TS-451A, TBS-453A, TS-551, TBS-453DX, HS-453DX, TS-262, TS-462, TS-662, TS-264, TS-464, TS-664, TS-464U, TS-1264U-RP, TS-x62C, TS-x64C, TBS-464:
      PartitionDescription
      /dev/sdaThe USB boot device
      /dev/mmcblk0The DOM (Disk On Module)
    • TS-251B, TS-253B, TS-453B, TS-653B, TS-253Be, TS-453Be:
      /dev/mmcblk1The DOM (Disk On Module)
    • All other NAS models:
      /dev/sdbThe DOM (Disk On Module) drive. The storage capacity of the DOM depends on the NAS model:
      • TDS-16489U R2 / TES-1885U / TES-3085U: 3.9 GB
      • TVS-h1288X/TVS-h1688X/TS-h3088XU: 4.64 GB
      • TVS-675: 4.7 GB
      • All other models: 492 MB
  15. Enter the following command:
    cd /lib/live/mount/medium/
  16. Enter the following command depending on your NAS model:
    1. TS-251A, TS-253E, TS-451A, TBS-453A, TS-551, TBS-453DX, HS-453DX, TS-262, TS-462, TS-662, TS-264, TS-464, TS-664, TS-464U, TS-1264U-RP, TS-x62C, TS-x64C, TBS-464:
      cp dom.img /dev/mmcblk0
    2. TS-251B, TS-253B, TS-453B, TS-653B, TS-253Be, TS-453Be, TS-453BT3:
      cp dom.img /dev/mmcblk1
    3. TVS-h1288X, TVS-h1688X, TS-h3088XU:
      cp dom.img /dev/sda
    4. All other NAS models:
      cp dom.img /dev/sdb
    5. The NAS system image is copied to the NAS DOM.
  17. After the NAS system image is copied to the NAS DOM, restart the NAS with the following command:
    reboot
  18. Remove the USB drive.
    The NAS starts up correctly and Qfinder Pro can now find your NAS.
  2. Open Qfinder Pro.
    Tip
  4. Right click on your NAS.
  5. Select Update Firmware.
  7. Click Start.
Install hard drives
  1. After the firmware is updated, perform the following steps to install hard drives:
    4. If the hard drives are new, you can continue to initialize the NAS. For details on initializing QTS or QuTS hero on your NAS, see the following:
      2. QTS Initialization (5.0.x)
Further Reading
Firmware Recovery Guide
Este artigo foi útil?
45% das pessoas acham que foi útil.
Obrigado por seu retorno.
Para obter mais ajuda, pergunte a outros utilizadores e aos especialistas da QNAP na comunidade. Ir para a Comunidade QNAP
Escolher especificação
      Mostrar mais Menos
      Fale connosco! Fale connosco!
