Why does QVR Face not complete the "stream from QVR Pro" process?
Last modified date: 2022-12-13
  • QVR Pro
  • QVR Face
Solution
CAYIN MediaSign Player is required to use a camera stream from QVR Pro.
A license for CAYIN MediaSign Player is required and can be obtained from the QNAP Software Store.
