How do I group and wake up multiple devices using QuWakeUp?
QuWakeUp
Solution
QuWakeUp allows you to group devices that can then be easily selected and configured to wake. These devices can either be selected individually, or made up of groups of multiple devices. This guide will explain the process of creating groups of devices, adding devices to groups, and waking multiple devices using QuWakeUp.
Create a group
- Log in to the device.
- Click New Group.
The New Group window opens. - Enter a group name and click Create.
Add devices to a group
- Select devices to add to a group.
- Click the Move device icon.
The Move Device window opens.
- Select a group.
- Click Move.
QuWakeUp moves the devices to the group. The number of devices is displayed next to the group name.
Waking multiple devices
- Select individual devices or a group.
- Click Wake Devices.
The Wake Device window opens.
- Configure the devices to wake immediately or set a wake up schedule.
- Click Apply. QuWakeUp wakes the devices according to the configured settings.
