Why does the NAS with add-on Adapter lose network connection if built-in Adapter is disconnected?
Applied Products:
All NAS Series
All QTS Firmware Versions
Scenario:
Why does the NAS, with built-in Adapter 1 and with add-on network card Adapter 2 (QXG-2G1T-I225 2.5GbE), lose network connection if the built-in Adapter 1 is disconnected? This may happen if QuFirewall is installed in the NAS.
Solution:
When Qufirewall is installed in the NAS, the QuFirewall will automatically create some Allow rules for the available interface (such as the built-in Adapter 1).
If an add-on network card (such as QXG-2G1T-I225 2.5GbE Adapter 2) is installed in the NAS, you need to manually set up an Allow rule for the add-on Adapter in QuFirewall.
Pro další pomoc se zeptejte ostatních uživatelů a odborníků QNAP v komunitě. Přejít do komunity QNAP
